 Post subject: BARRACUDA LP 2000GB
PostPosted: May 21st, 2011, 12:19
Rst 0x40M
RW: Disc Ctlr Initialization Completed.
MC Internal LPC Process
(P) SATA Reset
User Data Base 009918A8
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011985C 4011796C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00004213
[RSRS] 061B
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch
000017DB 00000000
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
 Post subject: Re: BARRACUDA LP 2000GB
PostPosted: May 21st, 2011, 14:26
2 topics for what?!?!?!
ACELab partner
PostPosted: June 5th, 2011, 15:28
A new firmware issue for CC31, right?
PostPosted: June 9th, 2011, 9:33
yes :The data resumes a method, thanks
PostPosted: July 14th, 2011, 14:06
I can do it! PM me if your terminal logs show
"No HOST FIS-ReadyStatusFlags 0002A1E1"
PostPosted: October 30th, 2014, 13:44
hello,
Use m0,6,2,,,,,22
then clear smart
power reset.
problem solved.
Waqas Ali
Users browsing this forum: Majestic-12 [Bot] and 51 guests
