ST500DM002 BUSY
May 22nd, 2014, 8:42
HELLO!
Not access terminal...
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
Busy 100%, rpm ok, not sound (clicks, clicks)...
Re: ST500DM002 BUSY
May 22nd, 2014, 16:37
Short read channel on PCB for starters
Re: ST500DM002 BUSY
May 23rd, 2014, 12:29
How to short??????
Re: ST500DM002 BUSY
May 23rd, 2014, 14:26
Nick_CT wrote:Short read channel on PCB for starters
Yes short channel pcb...
Sorry, not access terminal...
Is bad heads?
Re: ST500DM002 BUSY
June 10th, 2014, 9:17
Is bad heads?
Swap heads... is busy ....
log terminal
Boot 0x10M
Spin Up
RECOV Servo Op=0100 Resp=0005[0x00000000][0x0000BA10]
Trans.
Rst 0x10M
Spin Up
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
RECOV Servo Op=0165 Resp=0005
RECOV Servo Op=0065 Resp=0005
(P) SATA Reset
Re: ST500DM002 BUSY
June 10th, 2014, 16:34
Be patient
Re: ST500DM002 BUSY
June 10th, 2014, 16:44
labtech wrote:Be patient
SOLVED!
HEADS ORIGIANAIS...
Re: ST500DM002 BUSY
June 11th, 2014, 8:15
longlife wrote:How to short??????
yes!!
Re: ST500DM002 BUSY
June 11th, 2014, 8:36
SOLVED!
HEADS ORIGIANAIS...
I'm very sorry but i'm having a hard time trying to understand your posts.
Can you please elaborate on how did you manage to solve the problem with the drive ?
Re: ST500DM002 BUSY
June 11th, 2014, 9:01
Any kindhearted expert, please explain in what is written in this thread.
ST500DM002 BUSY
June 11th, 2014, 9:33
longlife wrote:please explain in what is written in this thread.
According to the terminal log, everything is OK with the drive.
With the info available for now there's nothing else to explain.
Re: ST500DM002 BUSY
July 8th, 2014, 7:17
could tell me what the pin as do the short read-channel in the pcb?
thanks in advance
Re: ST500DM002 BUSY
July 8th, 2014, 7:44
fali2004 wrote:could tell me what the pin as do the short read-channel in the pcb?
thanks in advance
Check this thread:
http://malthus.zapto.org/viewtopic.php?f=24&t=123&p=1632&hilit=read+channel#p1632
Re: ST500DM002 BUSY
August 5th, 2014, 4:40
Yesterday I was trying to unlock the terminal hard disk
Short read channel on PCB but did not have access
In the terminal reports me the following:
FAIL Op = 0100 Resp Servo = 0007
2BA0 ResponseFrame 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
LED: 000000EE FAddr: 0010289C
What can be happening? Please I need help.
Thanks in advance
Re: ST500DM002 BUSY
November 22nd, 2014, 13:10
fali2004 wrote:Yesterday I was trying to unlock the terminal hard disk
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
Thanks in advance
Same error, same symptom
Is there a any help?
