 Post subject: IBM sas drive in HP proliant ML330
PostPosted: December 11th, 2014, 8:47
Hello
I have an HP proliant ML330 with an HP smart array P410 SAS card.
when I put lot of various 'second hand) drive the P410 controlle reconize the drive and let me to manage them.
when I put IBM sas drive (seagate):
MODEL ST9146852SS
IBM FRU 45W3869
DOM : 10DEC2010
part number 9FU066-039
that's doesn't work, conroller do not see this drive
Do you think it's possible that the ibm firwmware have crypted function , or hp controller card have corporate code for use only hp disk with hp sas controller ?
 Post subject: Re: IBM sas drive in HP proliant ML330
PostPosted: December 11th, 2014, 9:35
possible the Seagate drive is "hardcoded" for a different architecture such as Dell or Acer. Not sure on how picky the actual card is though.
PostPosted: December 12th, 2014, 4:36
If ibm have hardcoded the seagate firmware, do you think it's possible to put the originale seagate firmware inside ?
IBM drive can't be plug in sas from other manufacturer ?
PostPosted: December 12th, 2014, 10:18
I don't know. I have heard so many different experiences with trying to use disks the vendors don't like... that I just don't bother anymore. It is too expensive time-wise and for very limited benefit. Seems each case is a try-it-and-see deal, which is a big No-No for servers!
PostPosted: December 12th, 2014, 19:51
This will be at least very far from being easy.
You aren't the first to think about such trick: http://forum.hddguru.com/viewtopic.php?f=1&t=29669#p205871
