 Post subject: Recover data that cant be detected in windows
PostPosted: December 11th, 2014, 8:24
I cant mount/retrieve the data inside the hdd. This hdd previously is used on a NAS storage. Any clue on how to retrieve the file?
Refer the image below, my computer can detect the drive. However, there is no 'file system' being detected by windows. The window using are window 7 Ultimate.
 Post subject: Re: Recover data that cant be detected in windows
PostPosted: December 11th, 2014, 8:42
Maybe the data are encrypted.
PostPosted: December 11th, 2014, 8:54
Is there any way to decrypt it so that i will be allow to access the data on it? I have the username and password.
PostPosted: December 11th, 2014, 8:59
in what kind of NAS was drive(one or more drives in NAS)
PostPosted: December 11th, 2014, 9:00
My NAS has four bay. There are 2 drive inserted. I wish to recover one of the drive. If i not mistaken, it is in JBOD.
PostPosted: December 11th, 2014, 10:20
Must guess as you didn't mention NAS maker: Most NAS are in EXT2 file format. To mount that type file system to windows use a product such as ext2fsd to begin.
PostPosted: December 11th, 2014, 11:56
It is very rare that I see each drive setup as their own JBOD...usually, at the very least, the main partition on each drive is merged together as a single JBOD. If the data is important to you, you may not want to risk playing with the drive too much and seek the assistance of your local data recovery professional while the cost to recover the data should be at the lower end of the pricing scale.
PostPosted: December 11th, 2014, 17:04
Try Linux Reader for Windows (freeware):
http://www.diskinternals.com/linux-reader
PostPosted: December 12th, 2014, 9:48
The maker of my NAS is seagate. The model is BlackArmor 400. I tried to mound using ext2fsd, but i cant access to the HDD. Check the picture below. I still cannot access to the drive.
PostPosted: December 12th, 2014, 9:52
Try UFSExplorer...if you can't see the file system with it, you will definitely need professional data recovery assistance.
I got the error message as attached.
PostPosted: December 12th, 2014, 10:06
I am able to see the file using this software. However, I am not sure the file can be read/usable since I do not have the license. Is it as long as I am able to detect the file using this software, the file should be able to retrieve if i have the license?
p/s: the HDD is still working.
 Post subject: Test data extraction with UFSExplorer without license
PostPosted: December 12th, 2014, 10:15
Wuulala wrote:
lcoughey wrote:
Try UFS Explorer...if you can't see the file system with it, you will definitely need professional data recovery assistance.
You can test data extraction on smaller files without license: https://twitter.com/UFSexplorer/status/365115243606716417
PostPosted: December 12th, 2014, 15:17
Can you read the other drive?
What was the capacity of the NAS?
PostPosted: December 12th, 2014, 23:26
The NAS does not include HDD. I purchase a 3.5'' HDD to be inserted to the NAS. I install 2 HDD inside the NAS, 1TB and 3TB.
 Post subject: Re: Test data extraction with UFSExplorer without license
PostPosted: December 13th, 2014, 11:49
Do you have any alternative software? Kindly advise me.
PostPosted: December 13th, 2014, 15:09
The reason I asked whether you could read the other drive was to determine whether the subject drive has a damaged file system, and whether the two drives have separate file systems.
PostPosted: December 15th, 2014, 3:39
Hello Wuulala,
to clarify few things:
you use this two drives in NAS (1TB and 3TB), total capacity was 1TB or 4TB?
Could you try Rstudio and try with RAID option
In any case, you will need to ourchase license for recovery.
PostPosted: December 15th, 2014, 5:59
jerovsek wrote:
Hello Wuulala,
In R-Studio you may try to preview files like jpg, pdf, MS Office, etc., in its demo mode, that is, before purchase.
And yes, you have to find whether this is a single drive, or a JBOD of 2 drives.
Users browsing this forum: Google [Bot] and 69 guests
