 Post subject: Need module 11 or modules for WD Pinclite 1.C7
PostPosted: December 28th, 2014, 8:12
Hello everyone!
I hope somebody could help me.
I have a PCB burned WD2500AAJS-00M0A0 drive.
With donor PCB i can access to SA, and i read out some modules.
After i regenerated ROM modules and write back to a donor PCB, the drive does not identified.
I can access to SA, but module 11 is corrupt.
Here it is the drive parameters:
WD2500AAJS-00M0A0
ROM FW REV.:1.C7
FW Version:01.03E01
DATE:2008.NOV.20
I need FW modules.
Thank you!
 Post subject: Re: Need module 11 or modules for WD Pinclite 1.C7
PostPosted: December 28th, 2014, 9:36
here is the closest FW Version: 01.03E01, ROM FW REV.:000100CS
you can try
good luck
11.zip [144.9 KiB]
Downloaded 253 times
Data Recovery Pakistan
PostPosted: December 29th, 2014, 11:58
Thank you MindMergepk!
I will try this one....
Thanks again
Users browsing this forum: Google [Bot] and 62 guests
