 Post subject: usb to sata pcb
PostPosted: January 13th, 2015, 5:16
hi,
I have 2.5 inch WD USB hard drive( WD10TMVV-11TK7S1 1.0 TB.). I want to swap the pcb with the compatible sata one. what is the compatible sata pcb to this usb pcb. please see details on below picture.
 Post subject: Re: usb to sata pcb
PostPosted: January 13th, 2015, 6:22
The forum has a neat feature up top called the search box.
viewtopic.php?f=1&t=28738&p=197932&hilit=701754#p197932
PostPosted: January 13th, 2015, 8:46
Try donordrives.com.
PostPosted: January 13th, 2015, 17:33
In general, you would look for a SATA PCB that has the same MCU and motor controller ICs. Ideally the USB and SATA PCBs will look identical apart from the bridge hardware at the front end.
Users browsing this forum: Google [Bot] and 82 guests
