Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Help repairing Hitachi 3TB drive - HDS723030ALA640
PostPosted: April 29th, 2015, 15:53
jermy wrote:
i'm sorry but the NVRAM usually contains the HDDs SN, i don't see it in your dump
HY1GEHAP
00002000  45 32 50 52 30 30 30 41 4D 4B 41 4E 42 33 42 30  E2PR000AMKANB3B0
00002010  20 20 20 20 20 20 4B 4D 33 30 31 31 48 59 31 47        KM3011HY1G
00002020  45 48 41 50 00 00 00 00 00 00 00 00 00 00 01 01  EHAP............
PostPosted: April 29th, 2015, 15:59
Spildit wrote:
I would check if PUIS is on. If your windows turned the PUIS on your drive that might explain the problem you described.
A lot of Windows 10 users are reporting PUIS (Power Up In Standby) problems after upgrading. The solution is to disable PUIS with a tool such as hdparm or HDAT2.
See http://answers.microsoft.com/en-us/insi ... 0cad9759c9
HDAT2 needs to be launched with the /w option to spin up the drive, ie ...
    HDAT2 /w
ISTR that Hitachi's Feature Tool can also disable PUIS. Booting from a Ubuntu Live CD would also automatically spin up the drive.
PostPosted: April 29th, 2015, 21:55
Spildit wrote:
Please confirm me that if you use another PCB from another compatible drive and if you swap the ROM chip to that PCB the drive will not spin at all, and if you swap just the PCB without swaping the ROM chip the drive will spin. Can you check that out with a compatible PCB ?
Yep this is the exact behaviour I am seeing.
    HDAT2 /w
Well $&#* I am using win 10 TP. will try the ubuntu live disk and see if that works
PostPosted: April 29th, 2015, 22:08
You were right, its a PUIS issue. I have been either hot plugging or using a external USB3 dock to test the drive. I shut down and plugged it in and it spins up on boot now!
I will follow that microsoft thread to disable PUIS.
Thank you ALL for your help. You saved my the trouble of sourcing another board and then realising that it would have done absolutely nothing!
Users browsing this forum: Bing [Bot] and 52 guests
