 Post subject: WD5000LPVX detected with partitions, then disappears
PostPosted: May 21st, 2015, 11:35
Have a Western Digital Blue WD5000LPVX, 500 GB 2,5'' SATA hard drive, which after some shock has a strange behavior.
The drive spins and there is no bad noise.
The drive answers correctly the "fdisk -l", listing partitions.
But when trying to clone it with ddrescue, it becomes undetected after a few seconds.
Before a mechanical repair, I'm just wondering if there would be some trick to attempt for this model of drive. I assume that some anomaly like for instance excessive temperature could make the drive behave not as usual.
The purpose is of course not to save the drive, but the data.
 Post subject: Re: WD5000LPVX detected with partitions, then disappears
PostPosted: May 21st, 2015, 13:23
need to diagnose properly,
it could be heads, FW, or typical slow problem
did you try the slow-fix ?
Data Recovery Pakistan
PostPosted: May 22nd, 2015, 13:24
Sir ,
Give it To a Data Recovery Company in your area and take a paid or free quote of analysis and estimate
PostPosted: May 22nd, 2015, 18:19
Spildit wrote:
Something like applying a slow fix (that disable relocation) and clone with something like DDI4 instead of a software only sollution might do the trick and spare you the trouble and expense of head stack replacement ...
Well ,
Thats one reason i am suggesting a estimate and check by a pro .You have anyone in that country suggest him i have no idea buddy
Users browsing this forum: No registered users and 28 guests
