Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Toshiba MK2555GSX PCB HELP!
PostPosted: July 16th, 2015, 4:12
Spildit wrote:
I would try to read the chip with something like this :
http://www.hddoracle.com/viewtopic.php?f=117&t=865
At least then you would know if the chip was killed or not. Then you could start looking for what to do next, depending on if you have valid ROM or not.
Rom chip was killed.
It's impossible to read anything via eprom :(
My firmware database:
PostPosted: July 16th, 2015, 4:56
if the problem is the GND pin, the metal pad area on the bottom center is also GND
PostPosted: July 16th, 2015, 5:39
No, it's not ground!
PostPosted: July 16th, 2015, 6:25
Have read out many ROM chips that was killed by bad soldiering like this one.
There are still hopes, but its hard work to connect to these bounding wires again.
If heat has not killed the chip - it can still be read.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: July 16th, 2015, 7:14
you're probably right, but for some reason - i don't know why - the datasheet says otherwise
here is what it says on an ST chip that has been used on PCB MK2555GSX G002439-0A
and here is another chip from winbond that it's been used on another toshiba PCB (note no. 4)
but there is no point to argue with you, because as i have written on the beginning you're probably right and it's not GND, and the manufacturers don't know what they are talking
PostPosted: July 16th, 2015, 8:28
There is a simple way to find out this, that's what i did!
Get a good working rom that has metal pad underside the plastic package and do a continuity test with a multimiter between metal pad and pin 4.
You will find out that there isn't any continuity!
PostPosted: July 16th, 2015, 8:46
I'm not surprised--given the heat damage and now I see from your recent post, physical damage. Geez, what a gorilla they have in that repair shop, to do that to a ROM chip!
I always worry about damaging a ROM when I have to unsolder it, so I heat up the circuit board instead of the chip itself, but it still makes me nervous. I unsoldered one yesterday and almost had a heart attack when, at first glance, I could no longer find the key dimple. I had the chip upside down. Hahaha. That ROM doesn't have a heat sink on the bottom but did seem to have some lettering. ROM was read by the programmer without problem. :)
PostPosted: July 16th, 2015, 23:38
The word "pulled" does not mean the same as "connected". Usually a pin is pulled high or low via a pullup or pulldown resistor. This resistance could easily be in the 10K+ range. Could this explain the apparent disagreement between measurement and datasheet?
Users browsing this forum: No registered users and 28 guests
