WD3200BMVW-11AMCS0 USB3.0
September 10th, 2012, 9:27
Hello gurus,
I have this drive comes with bad heads. After replacing the heads it imaged great until 37% then stopped and it has now a slow responding problem and very slow with delayed sectors.
My question is : I want to know the interchangeable SATA PCB with this USB3.0 PCB to fix the slow responding problem?
USB3.0 PCB # : 2060-771737-000 REV P1.
Thanks in advance.
Best regards,
Re: WD3200BMVW-11AMCS0 USB3.0
September 10th, 2012, 9:30
For USB 771737 you can use SATA 771692 from WD6400BPVT-22HXZT1
September 10th, 2012, 9:39
Thank you Mr.hddguy.
771692 also interchangeable with 1754 USB 2.0, right ?
September 10th, 2012, 9:45
unknown wrote:Thank you Mr.hddguy.
Yes , it will be compatible with 1754 also
September 10th, 2012, 9:50
Thank you very much sir.
I appreciate your kind help. :)
:good:
September 10th, 2012, 10:32
unknown wrote:Hello gurus,
Thanks in advance.
Best regards,
Humm, can you post images of BOTH hdd`s that you changed HEADS Patient & Donor?
just wanted to clear something in my HEAD about your case :!: :!: :wink:
thank you
September 10th, 2012, 10:39
WD3200BMVW-11AMCS0 USB3.0 : Patient
WD3200BMVW-11AMCS0 USB3.0 : Donor
Do you want the images of both drives?
September 10th, 2012, 10:47
Patient and donor :
September 10th, 2012, 10:48
Sorry for the bad quality of the pictures.
September 10th, 2012, 12:08
NP, thnx this helps
forgot to mention, nice Samsung Mobile btw
September 10th, 2012, 12:20
einstein9 wrote:forgot to mention, nice Samsung Mobile btw
lol :lol:
September 10th, 2012, 12:25
lol :lol:
He's been looking at hex again :lol:
September 10th, 2012, 12:36
in fact not used it for this
but Winhex is one of the MUST have tool in all of my DR pc`s
what a Powerful tool which i REALLY Admire
by looking @ their Office in Germany http://www.x-ways.net/corporate/location.html
i can say somewhere on the TOP which in fact IT IS....
September 15th, 2012, 13:19
Problem solved after finding compatible PCB 1692.
Many thanks guys.
Special thanks Mr.hddguy. :)
December 17th, 2012, 17:46
unknown wrote:Problem solved after finding compatible PCB 1692.
Many thanks guys.
I have problem with the same hard disk, usb connection isn't recognized from my pcs, this is mean pcb board is burn???? Tell me please, where are you find pcb 1692? i will try to replace, i hope it will fix.
December 17th, 2012, 22:48
That solution was to resolve a temporary firmware problem to recover data, NOT to necessarily fix the drive. That method would not be considered fixing the drive per se.
You are likely to have other issues. Question is what exactly? In order to determine that, can you describe in more detail your drive's behavior? For example, powered drive on and does not spin, etc.
August 27th, 2015, 5:22
hello, I have a hard drive western digital my passport 320 gb with the features in the picture.
Unfortunately, hard disk is no longer recognized by the PC and start feel two small hum. The LED lights.
if I change the circuit board can I fix it?
you can advise me what to buy and where?
thank you in advance
August 27th, 2015, 11:03
The PCB is more than likely not the problem.
Educated guess: drive was likely dropped or sustained some sort of physical shock and as result the internal components have gotten damaged or stuck in some king of way.
August 27th, 2015, 11:11
if the problem is just the PCB, you need 2060-771737, there is a lot of places to buy it, example 1, example 2 and there is more, but you will probably need to transfer the u12 chip.
the question is if it's the PCB, is there any noise from the HDD ?
August 27th, 2015, 11:25
labtech wrote:The PCB is more than likely not the problem.
+1
