 Post subject: st1000DM003 dead zones
PostPosted: September 5th, 2015, 4:31
Greetings friends ,
this is the second case i Had in the last month , Barracuda ST1000DM003 when i can image a very little areas of it Using DDI , then the drive will stop responding totally untill power reseted ..
drive takes almost 10 secs to ID .. nothing abnormal in the terminal LOG
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:001A
(P) SATA Reset
ASCII Diag mode
F3 T>
V40
Nonresident GList 0 entries returned
Total entries available: 0
PBA Len Flags Phy Cyl Hd PhySctr SFI
F3 T>/7
F3 7>X
Head 00 Resistance 00DA
Head 01 Resistance 017E
F3 7>
even on head one ( which shows a high resistance ) i can image some areas , while i cant image some sectors assigned to H0
please advise
thanks in advance
 Post subject: Re: st1000DM003 dead zones
PostPosted: September 5th, 2015, 5:37
isn't AltList full by any chance?
PostPosted: September 5th, 2015, 14:37
Looks like head 0 is dying.
http://www.rescue-it.se
PostPosted: September 5th, 2015, 15:18
i can't see anything wrong with H0. These heads have pretty wide range of normal resistance.
For example:
F3 7>X
Head 00 Resistance 018C
Head 01 Resistance 0215
Head 02 Resistance 0105
Head 03 Resistance 0157
Head 04 Resistance 0146
they are all good.
PostPosted: September 5th, 2015, 16:09
Yes I know, but 00 is pretty low.
PostPosted: September 5th, 2015, 17:01
where did u see 00?
PostPosted: September 6th, 2015, 8:09
I got a similar case. It could be on of the heads that is BAD.
Try to image by disabling heads one by one to see which one is BAD.
Then You can disable it and image the other areas. At the end you can try with the bad one.
PostPosted: September 6th, 2015, 11:42
Thanks for the precious hints thought !
this is the log with lists and smart ..
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:001F
(P) SATA Reset
ASCII Diag mode
F3 T>/1
F3 1>N5
Att
Num Flgs normlzd worst raw
1 000F 64 64 00000000000000
3 0003 62 62 00000000000000
4 0032 64 64 00000000000007
5 0033 64 64 00000000000000
7 000F 64 FD 00000000000000
9 0032 64 64 00000000000000
A 0013 64 64 00000000000000
C 0032 64 64 00000000000007
B7 0032 64 64 00000000000000
B8 0032 64 64 00000000000000
BB 0032 64 64 00000000000000
BC 0032 64 FD 00000000000000
BD 003A 64 64 00000000000000
BE 0022 45 45 0000001F1F001F
BF 0032 64 64 00000000000000
C0 0032 64 64 00000000000008
C1 0032 64 64 00000000000007
C2 0022 1F 28 0000190000001F
C5 0012 64 64 00000000000008
C6 0010 64 64 00000000000008
C7 003E C8 FD 00000000000000
F0 0000 64 FD 00105B00000000
F1 0000 64 FD 00000000000000
F2 0000 64 FD 00000000000000
0 0000 0 0 00000000000000
F3 1>
ASCII Diag mode
F3 T>V2
System Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI
0 0 0 0 0 0 0 380C2 0 FFFFFFFF 0
62B42 151BE 151BE 0 1 0 1 33E0B 0 FFFFFFFF 77D00
C5684 151BE 2A37C 1B0 0 0 2 38272 0 FFFFFFFF EFA00
1281C6 151BE 3F53A 1B0 1 0 3 33FBB 0 FFFFFFFF 167700
Head 0: entries 2 slips 151BE
Head 1: entries 2 slips 2A37C
Total Entries 4 Total Slips 3F53A
F3 T>
ASCII Diag mode
F3 T>V4
Reassigned Sectors List Enabled
Entries: 0001, Alts: 0000, Removed: 4013,
Pending: 0001 Host Pending: 0008
Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msecs Status BBM Mask
0000 00000E968969 00000E97A2FD 05A016.0.001D 0D7 05A376.0.001D 055B19 00000 008BD5 00000001 00000000
F3 T>
PostPosted: September 8th, 2015, 10:20
From all the terminal responses, it seems like you may either have failed translator or failed smart. Most likely important modules in the service area are not readable. Try to clear alt list and smart.
PostPosted: September 10th, 2015, 8:27
thanks for the hints ..
can you please advise how to clear the alt-list ?
PostPosted: September 10th, 2015, 8:53
pm sent
Users browsing this forum: jimmydata and 69 guests
