 Post subject: Looking for Donor for WD3200BMVU
PostPosted: September 9th, 2015, 13:12
WD3200BMVU - 11A04S0
HANT2ABB
SEP 2009
THAILAND
0 - 2338
1 - 2412
2 - 2364
3 - 2402
Cannot find one anywhere......
 Post subject: Re: Looking for Donor for WD3200BMVU
PostPosted: September 9th, 2015, 16:38
What do you need? Heads or PCB or complete drive?
http://www.datasaversllc.com
PostPosted: September 9th, 2015, 16:48
Heads for a head swap :D Cant find one with the right DCM anywhere....
PostPosted: September 9th, 2015, 17:54
Hello
Did you llok in the sata brother ?
WDXXXXBEVS or so ?
Good Luck
Récupération de Données
PostPosted: September 9th, 2015, 18:16
w.simon wrote:
Hello
WDXXXXBEVS or so ?
Good Luck
I can find a lot of SATA drives but none with 'A04' in the second parts of the number.
There are a lot of A03's but not sure about compatibility??
PostPosted: September 9th, 2015, 19:53
Match DCM characters 5 & 6 on a Venus 4 head stack and you should be good to go. A04 / A03 isn't important.
PostPosted: September 9th, 2015, 19:56
Thanks for the advice all, as always..
PostPosted: September 9th, 2015, 20:02
http://www.donordrives.com/wd3200bevt-7 ... drive.html
A03 is a Pluto
PostPosted: September 10th, 2015, 3:11
what he says^
Or try a Denali with 4 heads. It will work.
PostPosted: September 10th, 2015, 9:07
northwind wrote:
what he says^
^ What he says. :-)
PostPosted: September 10th, 2015, 11:49
+1 Try a Denali
Had some trouble finding a Marn5 4K HSA until Northwind cleared that Marn5 4K and Mariner where compatible :)
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 10th, 2015, 14:44
digisupport wrote:
+1 Try a Denali
Thanks for the help. How do you know if another drive family will work as a donor?
PostPosted: September 10th, 2015, 14:54
You ask an expert. :-)
PostPosted: September 10th, 2015, 14:56
LOL, indeed.....
Users browsing this forum: jimmydata, Majestic-12 [Bot] and 57 guests
