 Post subject: Toshiba 2.5" MQ01UBD100 USB Drive c/w USB PCB
PostPosted: February 26th, 2015, 18:19
Anyone had any experience with these? Its the first Toshiba with integrated USB board I have seen. Anyone had experience of soldering a SATA connector to it? Or is there a list of matching SATA/USB PCB's like WD (I suspect not). It may also be encrypted. This drive is clicking so need to test on the PC3000 via SATA. Any help would be appreciated.
 Post subject: Re: Toshiba 2.5" MQ01UBD100 USB Drive c/w USB PCB
PostPosted: February 26th, 2015, 21:16
Well, there is this thread: viewtopic.php?f=1&t=26163&start=0.
PostPosted: February 26th, 2015, 22:07
Yes I should have checked :oops: Thanks :)
PostPosted: February 27th, 2015, 3:22
If it's clicking, then almost certainly it's an internal issue (I.e. Heads and/media damage).
But to convert to SATA, just select a SATA PCB with same MCU and motor chip, then transfer IC602
Doubt it will be hardware encrypted, never seen this on Toshiba.
PostPosted: February 27th, 2015, 6:30
Nope, they're not encrypted.
PostPosted: September 18th, 2015, 9:14
Hello ,
Northwind and Pcimage Are All of Them Not Encrypted .I Have a Case Today That i Would Be Posting Seperately Needed Some Advise
Users browsing this forum: jimmydata and 68 guests
