 Post subject: Fujitsu HSA matching criteria?
PostPosted: January 12th, 2016, 15:50
I've been looking for a Fujitsu 2.5" 250GB model MJA2250BH, P/N CA07083-B50400AP donor drive and they are scarce. Can anyone suggest alternatives or tell me what parameters are critical for compatibility? Or are they like Toshibas and almost anything goes?
 Post subject: Re: Fujitsu HSA matching criteria?
PostPosted: January 12th, 2016, 16:04
found 3 of them https://www.harddrivesforsale.com/catal ... 3-B50400AP
PostPosted: January 12th, 2016, 20:35
Thanks, jermy but like most other suppliers, they are "Out of Stock!" I managed to find one at donordrives.com and they are kindly holding it for a day while my customer mulls the cost. I'd still be interested to know if one of the donors I have in hand might do the job.
PostPosted: January 12th, 2016, 21:37
heads swap importance:
same model and same part number
personally i'm trying to find the closest DOM
PostPosted: January 12th, 2016, 21:44
That's what I have been using/doing. Was just hoping there is more flexibility but I'm probably a dreamer.
PostPosted: January 13th, 2016, 17:23
If you have in stock something similar - just try.
PostPosted: January 13th, 2016, 18:13
I would, but I don't have anything similar that doesn't have bad heads, unfortunately.
PostPosted: January 13th, 2016, 18:45
I can give you MJA2250BH.
PostPosted: January 13th, 2016, 21:44
drHDD, thanks! See PM.
PostPosted: January 17th, 2016, 10:11
They seem to be quite flexible if you can match the series and the headmap.
Like a MJA2160BH donor would work for a MJA2250BH patient if headmap is the same.
Data Recovery Cape Town
PostPosted: January 17th, 2016, 11:32
Thanks, Nick.
