 Post subject: Hitachi - Serial No Identification Help Required
PostPosted: March 9th, 2016, 12:11
Hello Peers ,
Got a Case Of a ARM Series Hitachi .Model No is HDS721050CLA662 .Its a 500GB .Drive Does Not ID .In PC3k I Selected Custom And PCB Only Access .Utility Starts But i Cannot See Anything If i Select Visual NVRAM Editing .I Am Able To Read Both NVRAM And ROM .Can You Help Me Identify "Serial No " In ROM/NVRAM And Also Tell Me What Method They Store This .I Am Able To Find Many Segments With Signature "E2PR " .Serial No of My Drive is JP1572FN15TMWK And MLC Is : JPT41A
Data.zip [92.85 KiB]
Downloaded 343 times
 Post subject: Re: Hitachi - Serial No Identification Help Required
PostPosted: March 9th, 2016, 17:16
sorry but it's not the original NVRAM
this NVRAM was taken from JP1532FR2LXMKK (begins @ 0x16)
PostPosted: March 10th, 2016, 1:37
Hi Jermy ,
I Took a Picture For Another Drive " Hitachi HDS721010DLE630 " .The Serial No Here is " MSE5235V0MRJRL " .See This Screenshot
The Last digits Are Reversed In NVRAM LR Though Serial No Is RL ,Then JR And RJ,Then M0 And 0M ,And So On .So Is This Method Called Byte swap ? Or What .What i did Is That i started PC3K With Hitachi HDS721010DLE63 Drive Connected And Opened The NVRAM Of This Then i Loaded The NVRAM Image of The Other Drive Whose Serial No i Was Not Able To Find And I Got The Result As You Gave Me Spot On ,Thanks For Helping Brother .The ROM is Not Original and Hence Is There a Point Handling This Case ? . Spildit Was Once Talking Along With Drdoc For Directly Accessing Sectors Via ABA/PBA Etc ,In This Drive Due To Wrong ROM The Drive Spins Down It would Be a Had Issue Also
Pictures.zip [691.58 KiB]
Downloaded 333 times
Users browsing this forum: Google [Bot] and 89 guests
