Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Cleaning tools for platters
PostPosted: March 10th, 2016, 3:57
pepe wrote:
of course i meant that only one head is mounted in that case.
Well,
Assuming its a 2 Platter Drive With 4 Heads .So What will You Do ,Physically Use a HS With One Head Or Physically Cut Other 3 Heads And Use Many Donors ? . Because If You Use 4 Head Stack Definitely Platter/Head Damage Will Be There .
PostPosted: March 10th, 2016, 4:28
infofaster wrote:
Hi guys,
I have clean the platters sucessfuly with Sm. Knit Poly Swab, Rigid Tip one with IPA (Iso Propyl Alcohol 100% pure) and other only to clean and swap the liquid that remains. I do it in cycles from center of the platters to outside and it works. The platter is cleaned :lol: was you can see in this picture:http://files.hddguru.com/index.php?action=view&filename=platters%20cleanded.jpeg.JPG&directory=Hard%20disk%20Pictures/Hitachi/SATA&
I want to thanks for all the tips and replys this post have. :mrgreen:
Hi InfoFaster ,
Could You Please Provide Me With some More Details [ If You Can i Can Ask Here Or PM You ] .
PostPosted: March 15th, 2016, 14:43
How would u clean multi platters surface that are still assembled together?
Some of u does know how to realign platters after having dismounted from each other?
My firmware database:
PostPosted: March 17th, 2016, 2:42
Without Some Precision Machine IMHO its Not Possible .Might Be Its possible by a different Technique That i Think Might Work " but i Need To Try It Out " . But Thats Not For Public Domain .I Have Now Arranged Most of The Material For Platter Cleaning And I am Now Going To start This In Scrap Drives And Master The Technique In My Own Way [ For Cleaning Platters And Heads ] .
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 49 guests
