 Post subject: finger touch on the platter!
PostPosted: April 3rd, 2016, 2:47
Hi folks,,
I recieved external HDD 500 GB WD5000BMVV-11GNWS0, it's opned by someone and he made farther damage on the platter by finger touch.
the HDD need to make head swap, I have identical HDD drive to do head swap, but before I make that,
How I can remove finger touch from the platter without leave any effect on it? in order to protect new head from damage
note that: I make experiment to use alcohole pure 96% on other HDD, but it's leave some "Bubbles" on the platter
patient HHD photos
http://www.mediafire.com/view/8smuihc2m ... G_0035.JPG
http://www.mediafire.com/view/wb1zkvlg2 ... G_0037.JPG
http://www.mediafire.com/view/92e93dg94 ... G_0032.JPG
http://www.mediafire.com/view/ej1vwkrw5 ... G_0038.JPG
Experiment to use alcohole pure 96% on other HDD
http://www.mediafire.com/view/48x46hzzr ... G_0040.JPG
Expect, the Unexpected
 Post subject: Re: finger touch on the platter!
PostPosted: April 3rd, 2016, 5:55
eng.mas wrote:
Hi folks,,
patient HHD photos
Well,
There DR Guys Here will Not share Such Secrets ,Though i Am Aware of Few Things .First of All this is My Observation .
1 : Your Head And Platter Metallic Base Tool Is Dirty ,Clean The Damn This .To Do That Take a Lint Free Cloth ,There Are Many Type of Lint Free Cloths Some Of Them Absorb Liquids "Use One Like That " ,Spray Alcohol On It 99.9% Medical Grade And Clean Your Laminaar Flow Bench And Also This Tool .
2 : Now Comming To Your Current Question .This Platter Looks Bad But Try Cleaning With a Sterile Cleaning Pad With Alcohol Already in It .Or Take a Very Fine Brush Under Just Less then 1 CM Dip It In 99.9% Alcohol And Clean From Center To Edge Making sure The Liquid Goes Towards The Edge .
PS : i am Aware of 5 Chemicals Used for this But My Experience is Not Upto Mark in this Yet But By Allahs Grace Would Be Soon .
PostPosted: April 3rd, 2016, 8:10
Acetone and a cleanroom wipe works well. Even 99.9% pure IPA leaves streaks on the platter, in my experience.
PostPosted: April 3rd, 2016, 10:11
Well,
And Openly the Only Helpful Guy Across All the Forums ,Well done Mr Larry ,Then Pure Acetone He Can Try
PostPosted: April 4th, 2016, 1:06
first of all thank you Amarbir[CDR-Labs] for your reply
Amarbir[CDR-Labs] wrote:
Well,
Before I make this post, I was hesitate, because I know some DR Guys will consider that is Secret, But I know some member in this furom like to share and help other!
about myHead And Platter Metallic Base Tool, you are absolutly true :) ,
I'll try your recommandation on other HDD to see the result before make this on the patient HDD.
But can I use cotton bud instead of a Sterile Cleaning Pad OR two of them the same!
PostPosted: April 4th, 2016, 11:34
Well,
Try Both and also The Brush As I stated ,When We Try We will Learn And Success Will Come At Our Feet
