 Post subject: Seagate ST500DM002 Broken
PostPosted: April 4th, 2016, 10:41
Hi there!
I have an old 500GB hard disk unit Seagate which suddenly has died within my computer.
At physical level it sound pretty good, but It's not recognized by any computer/operating system... From some preliminar researches, I'm thinking about PCB controller change from any other old harddisk from ebay.
I've found lot of ST500 but I'm just trying to ensure that core parameters are similar i.e. firmware version (KC44 in my case). Just two quick questions, which hopefully you could answer easily:
Are there any compatibility charts in terms of firmware version or models? and maybe before... Do you think that PCB Controller change it's a feasible option in this case?
My HD datasheet is:
S/N Z2AEHGKS
ST500DM002
P/N 1BD142-301
Firmware: KC44
Thank you very much!
Best Regards,
Nyrco
 Post subject: Re: Seagate ST500DM002 Broken
PostPosted: April 4th, 2016, 10:59
changing pcb will not help in this case.
Data Recovery Pakistan
PostPosted: April 4th, 2016, 11:09
most likely not a PCB issue, if you insist you can try.
anyway the details you have provided:
Nyrco wrote:
My HD datasheet is:
S/N Z2AEHGKS
ST500DM002
P/N 1BD142-301
Firmware: KC44
is irrelevant, what matters is the PCB no. : (like 100535704 for example) + you need to transfer the what so called ROM chip
PostPosted: April 4th, 2016, 11:28
Seems It's quite clear for everybody that PCB is not the key issue. Sincerely I hope that was a solution because it's affordable... I've seen potential HD donors around 50-80€ meanwhile a company budget could be arround 500€ :?
If I'm not wrong PCB no: 100498558
PostPosted: April 4th, 2016, 11:36
Nyrco wrote:
Hi there!
My HD datasheet is:
S/N Z2AEHGKS
ST500DM002
P/N 1BD142-301
Firmware: KC44
Best Regards,
Nyrco
if drive is spinning fine and there is absolutely no abnormal sound, you should get a TTL adapter, hook your drive and post terminal log here, which will help you and other members to understand the problem.
PostPosted: April 4th, 2016, 13:15
Ok I'll try.
Is there any specific post of how to connect TTL adapter?
PostPosted: April 4th, 2016, 13:38
Spildit wrote a guide
Users browsing this forum: No registered users and 80 guests
