 Post subject: Seagate HD Stopped working, should I replace the controller?
PostPosted: April 11th, 2016, 11:14
Hi guys! I'm desperate for some help.
My 3tb Barracuda HD just stopped working, the computer or the HD did a bip sound and the HD never came again, after multiple reboots, tried to put it on another computer same results. It does some clicking sounds for a little bit, but once windows is up and running it stops. I do have backup of most of the stuff, but not all. I would like to recover if possible. I do have another drive from the same exact model at home. But I am not sure if I can take the controller from one and just put on the other just because its the same model, has anyone done this before? Can the controller of the working drive brake too if I try to use on the broken one?
Broken HD
Model: ST3000DM001
PN: 9YN166-302
FW: CC4C
Date: 12293 SITE: WU
Controller code: 100664987 REV A
WORKING HD
Model: ST3000DM001
PN: 1CH166-301
FW: CC24
Date: 13277 SITE: WU
Controller code: 100687658 REV C
Thanks!
Raf
 Post subject: Re: Seagate HD Stopped working, should I replace the control
PostPosted: April 11th, 2016, 11:46
If data is important, do not connect your drive any more. These DM series are very fragile, there is a big risk that just powering the drive will make the situation worse. Seek pro assistance your error is not controller related.
Digitalsupport Data Recovery
https://digitalsupport.dk
