 Post subject: seagate momentus thin problem
PostPosted: April 9th, 2016, 6:26
hi
i'm trying to repair that hardisk
this video explain my problem: https://sendvid.com/6oiprtf6
i think that replacing heads will solve my problem.
someone can help me please?
 Post subject: Re: seagate momentus thin problem
PostPosted: April 9th, 2016, 13:51
Why do you think the drive failed? Was it dropped?
PostPosted: April 9th, 2016, 14:16
is this the actual video of your drive ?
did you power it up while back lid open ?
Data Recovery Pakistan
PostPosted: April 11th, 2016, 3:57
yes... i hope that it hasn't made my hardisk irreparable
i don't know the story of this drive.
When i connect it i hear some noises but it is not recognized from pc.
This is my first time i try to repair an hard drive... my job is repair phones and other hardwares
PostPosted: April 11th, 2016, 4:50
OMG, you wanna tell me that this drive doesn't belong to you, & it actually belongs to a client ?!
PostPosted: April 11th, 2016, 5:09
yes
PostPosted: April 11th, 2016, 18:04
So far, has been attempted is not good. Recommended not to proceed like this in the future. Also, always ask customer to tell you to the best of their knowledge what may have happened. Reason being is, say the drive was dropped, then powering on is a mistake.
Replacing the heads may help in the sense that a heads replacement might be what is needed, but not 100% sure as other faults should be ruled out first. Running the drive without cover is misleading.
PostPosted: April 12th, 2016, 5:33
where can i buy a replacement heads unit?
PostPosted: April 12th, 2016, 5:54
1. You can't, you buy a complete matching donor HDD, taking out the HSA and replacing it.
2. don't do that, the chances of success is not in your favor (need tools, knowledge, clean room/chamber), not to mention the work needs to be dealt with afterwards, FW issues, hardware imaging.
my advice: send it to a pro
PostPosted: April 12th, 2016, 11:52
You are doing your client a tremendous disservice, putting his or her data at great risk. Please stop experimenting with it, and send it to a pro.
http://www.datasaversllc.com
PostPosted: April 20th, 2016, 7:45
Terminal is useful thing on Seagate F3 drives.
Try to connect it to the drive and send us the report from the drive.
Users browsing this forum: Google [Bot] and 78 guests
