 Post subject: Is PCB WD 2061-701640-802 compatible with 2061-701640-002 ?
PostPosted: April 27th, 2016, 12:25
Does someone know if the PCB with suffix 802 can replace the PCB with suffix 002 ?
It's for a WD Caviar Green ; drive model and P/N are same.
Which is the signification of the suffix in the PCB-number of Western Digital drives ?
Thanks.
 Post subject: Re: Is PCB WD 2061-701640-802 compatible with 2061-701640-00
PostPosted: April 27th, 2016, 13:42
if drive family is same it should work.
seems a dragnfly2 family, right ?
Data Recovery Pakistan
PostPosted: April 27th, 2016, 14:23
can.if the same bootloader.
PostPosted: April 28th, 2016, 10:53
No Friends. If pcb is this 1640-001 this not work. If the 1640-002 it should be work. Autor have a oryginal rom content?
PostPosted: April 28th, 2016, 15:22
I've seen some anomalies with that number being off. For example I've seen where you could read but not write data using a certain set of heads because of this number being different. Definitely try to match the whole PCB number, but if you have it handy, it doesn't hurt to try it.
Users browsing this forum: Google [Bot] and 73 guests
