 Post subject: Something happened to this MAC Drive?
PostPosted: May 15th, 2016, 15:52
Hello guys,
already cloned the drive.. wondering why there is a FAT32 partition at the beginning of the drive. Might this be the cause why the HD is not recognized? R-Studio does not have any problems extracting files...
Maybe someone mounted it to a windows pc? Does this write a partition?
some non technical side story: She wanted the MAC to be repaired by a store (the owner owes me 2000 € - weird guys - funny she didn't knew that at that time) they damaged the MAC and said there was a problem with the drive not readable.. but before the MAC worked fine beside the touchpad problem.... really weird story... - after that she was at a PC repair shop maybe the mounted it and the partition was written to the drive
I hope I can use the MAC migration tool to transfer the settings e.g. to the new MAC of a friend of mine. Once the partition is fixed it is worth a try to use the MAC migration tool?
diskutil list with terminal doesn't list the attached usb drive... strange..
Greetings
Benjamin
Fachwerkstatt für Data Recovery / Datenrettung in Stuttgart - Riedel IT - Ameisenbergstraße 30 - 70188 Stuttgart
 Post subject: Re: Something happened to this MAC Drive?
PostPosted: May 15th, 2016, 16:01
Now it have been shown in terminal session using
diskutil list
but mounting is not possible ? but maybe the target drive has some issues
wondering how to get the partition recoginzable by a mac
PostPosted: May 15th, 2016, 16:08
This is the result of the command.. maybe the error has something to do with the FAT32 partition written to the beginning of the drive?
diskutil verifyvolume disk2s2
Started file system verification on disk2s2 Macintosch SSD
Verifying file system
File system check exit code is 8
Error: -69845: File system verify or repair failed
Underlying error: 8: POSIX reports: Exec format error
Benjamins-MBP:volumes Benjamin$ diskutil repairvolume disk2s2
Started file system repair on disk2s2 Macintosch SSD
Repairing file system
Updating boot support partitions for the volume as required
PostPosted: May 15th, 2016, 16:13
Tried some things...
time to go to bed
/dev/disk2 (external, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *500.1 GB   disk2
   1:                        EFI EFI                     209.7 MB   disk2s1
   2:                  Apple_HFS Macintosch SSD          239.2 GB   disk2s2
   3:                 Apple_Boot Recovery HD             650.0 MB   disk2s3
Benjamins-MBP:~ Benjamin$ sudo pdisk /dev/disk2s2
pdisk: can't open file '/dev/disk2s2'  (Resource busy)
Benjamins-MBP:~ Benjamin$ sudo diskutil unmount /dev/disk2s2
disk2s2 was already unmounted
edit...
pdisk: No valid block 1 on '/dev/disk2'
Edit /dev/disk2 -
Command (? for help): i
pdisk: can't open file '/dev/disk2' for writing (Resource busy)
PostPosted: May 15th, 2016, 16:45
getting crazy on this... now used the original drive ... same pattern... Any tools that can handle this repairing partition issue?... rstudio works fine for recovering files...
   0:      GUID_partition_scheme                        *240.1 GB   disk2
Benjamins-MBP:~ Benjamin$ sudo diskutil unmount /dev/disk2s1
disk2s1 was already unmounted
Benjamins-MBP:~ Benjamin$ sudo diskutil unmount /dev/disk2s3
disk2s3 was already unmounted
Benjamins-MBP:~ Benjamin$ sudo diskutil unmountdisk /dev/disk2
Unmount of disk2 failed: at least one volume could not be unmounted
PostPosted: May 16th, 2016, 5:03
The FAT32 Partiton - it was not a fault..
Wikipedia
On Apple–Intel architecture Macintosh computers, the EFI partition is initially blank and not used for booting.[11] However, the EFI partition is used as a staging area for firmware updates;[12] specifically, it places a firmware flash utility (EFI binary) and data file (FD – "Firmware Device"[13]) in the directory EFI/APPLE/FIRMWARE which is then run when rebooting the system in "flash firmware" mode.[
In the end there is still a question:
How make the the partition mountable?
Users browsing this forum: Google [Bot], mima85 and 186 guests
