 Post subject: RAID 0 recovery
PostPosted: June 14th, 2016, 23:11
I have a Fantom 6TB external hard drive that uses two 3TB hard drives. On the back it has two switches for setting up RAID. I have it set to RAID 0 so I can use the full 6TB. The problem with it is that it won't power on. So I pulled the hard drives out to get to the data.
I cloned the drives without any errors.
I want to rebuild the Raid with UFS Professional Recovery , but i don't know the the stripe size. Ho do i get the stripe size from cloned drives and how can i rebuild the RAID?
 Post subject: Re: RAID 0 recovery
PostPosted: June 15th, 2016, 7:12
Can guess by trying all options available, or with with more knowledge, analyze data content.
PostPosted: June 15th, 2016, 13:02
I dont have knowledge about recovery.... i am just asking for help,,,,
PostPosted: June 15th, 2016, 13:15
First off, greetings from Providence!
I could be wrong, but I think a good number of those use a 1 sector stripe size (512 bytes). I'm not positive if UFSExplorer supports that, but I know R-Studio does. You just have to manually type the value in, as it's not a standard size in the drop down. If you need any help, feel free to PM me.
Jared
PostPosted: June 15th, 2016, 14:08
Thank You ! I did it with R-studio !!!
Users browsing this forum: Google [Bot] and 74 guests
