Hard disk drive 80GB circuit PCB repair
June 20th, 2016, 7:35
platinum burnt hard drive PCB
I have received a burnt hard drive PCB
I sent the attached picture wish to you help to replace data recovery
thank you
Re: Hard disk drive 80GB circuit PCB repair
June 20th, 2016, 9:30
Find an identical PCB, transfer the U12 ROM physically or logically and you should be good to go...unless the head pre-amp is damaged too.
