 Post subject: Loader for WD Shrek
PostPosted: July 26th, 2016, 10:29
Hello data recoverers,
Could you please share loader module(s) for this drive? It's a WD15NMVW-11AV3S0.
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 318 347
SA regions address...................... : shifted
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 01.0GG
ROM F/W version......................... : 0001000G
Overlay F/W version..................... : 01.0HG
Servo F/W version....................... : 00.04
Heads configuration..................... : by map
Heads number............................ : 8
Heads number in use..................... : 8
Switched off heads...................... : No
Heads map............................... : 0,1,2,3,4,5,6,7
Thanks in advance!
 Post subject: Re: Loader for WD Shrek
PostPosted: July 26th, 2016, 11:25
It's right here on this site
http://files.hddguru.com/download/PC-30 ... 3D9524.rar
PostPosted: July 26th, 2016, 11:59
Thanks Doomer,
I've used that one before, but it seems to be incompatible someway. It scrambles the RAM headmap (it shows like 1 2 3 4 5 6 7 0, and 7/8 or 1/7 heads active, which is wrong). I've seen these behaviors with "almost compatible" 11-modules, but don't know if this is the case yet. I'd like to try another option if available :o
PostPosted: July 26th, 2016, 12:35
Here's mod 11 from a 2Tb version...
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1480
>ROM:
>ROM reading............................. : Ok
>ROM generation.......................... : 01.0HG
>Link table version...................... : 00.04.
>Consolidated ROM version................ : 0001000G
>ROM Modules:
>SA regions address...................... : by default
>ROM Firmware version.................... : 0001000G
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [424.91 KiB]
Downloaded 467 times
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 40 guests
