Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: MK6026GAX does not spin
PostPosted: August 7th, 2016, 15:39
I tested a bunch of PCBs -- Samsung, Hitachi, WD and Seagate. As expected, none had shorts between any motor phase and ground. A genuine short would mean that the motor controller is bad. Clearly your board does not have a real short.
I suggest you retest the PCB tomorrow. Perhaps there is residual voltage on the gate capacitances of the low-side MOSFET drivers which is responsible for the false readings. In fact that's how you would test a discrete MOSFET with your multimeter -- charge up the gate and then measure the resistance between drain and source.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 39 guests
