 Post subject: More Seagate SSHD Issues
PostPosted: August 26th, 2016, 18:08
I have a ST500LM000. I'm seeing a lot of these SSHD drives most with stiction, however this is different.
This drive is imaging very slowly, I would say its firmware rather than heads but not sure. I have changed SMP parameters. CTL-X gives normal reading of SA without errors, no strange messages on start up. But the drive gives the below terminal output when imaging. Interestingly building a head map in DE was strange, it built fine for the first 25% then almost stopped for a few minutes, then chunks away again to the end.
Any ideas?
Set Transfer Mode selected
Ultra DMA selected
Starting LBA of RW Request=0002C757B4  Length=00000020
ProcessRWError -Read-   at LBA 0002C757CD  Sense Code=43110081
Starting LBA of RW Request=0002C757F4  Length=00000020
ProcessRWError -Read-   at LBA 0002C757F4  Sense Code=43110081
ProcessRWError -Read-   at LBA 0002C757F5  Sense Code=43110081
Unrecoverable Error Reported
Unrecoverable Read Verify Error Reported
(H) SATA Reset
SSPSaveSettings
SSPRestoreSettings
Send Status: COMRESET seen
Starting LBA of RW Request=0002C757F4  Length=00000001
Ultra DMA selected
ProcessRWError -Read-   at LBA 0002C77430  Sense Code=40000087
Starting LBA of RW Request=0002C77430  Length=00000020
ProcessRWError -Read-   at LBA 0002C77434  Sense Code=43110081
Starting LBA of RW Request=0002C77450  Length=00000020
ProcessRWError -Read-   at LBA 0002C77451  Sense Code=43110081
ProcessRWError -Read-   at LBA 0002C77456  Sense Code=43110081
(H) SATA Reset
SSPSaveSettings
SSPRestoreSettings
Starting LBA of RW Request=0002C77450  Length=00000001
ProcessRWError -Read-   at LBA 0002C77450  Sense Code=43110081
Starting LBA of RW Request=0002C77451  Length=00000001
 Post subject: Re: More Seagate SSHD Issues
PostPosted: August 29th, 2016, 1:35
had same issue after changing Heads it works fine.
PostPosted: August 29th, 2016, 2:50
+1 for new heads i this case
Digitalsupport Data Recovery
https://digitalsupport.dk
