 Post subject: seek error
PostPosted: January 26th, 2005, 11:45
hi users board
i have problem with wd300ab -00bva0
this hdd is droped on the table then tried to work it again after the drop
its occure clicks only 4 times only but i heard sound for seek heads is noise
then this hdd work good after those clicks
i maked check by pc 3000 all firmware are ok and surface also are ok
but in mhdd seek shows error in some of sector
i need help to disconnect this error from hdd
thanks
mohamed eltamsy
 Post subject:
PostPosted: January 26th, 2005, 13:05
In MHDD use F4 and put the option ERASE WAITS on.
 Post subject:
PostPosted: January 27th, 2005, 5:25
thanks on concern
i will try that
thanks
mohamed eltamsy
Users browsing this forum: No registered users and 103 guests
