 Post subject: WD30NMVW-11C3NS2
PostPosted: September 21st, 2016, 1:21
Hello Friends,
after long time i am joining here.i found there is 3TB usb HDD western digital WD30NMVW-11C3NS2.this is also new to me.i surprise in there PCB size and designing's let me know there is encryption by USB and anybody found way to connect SATA terminal.i am just searching for USB controller chip for finding point of Sata input to controller.can help in this matter?
safwan
 Post subject: Re: WD30NMVW-11C3NS2
PostPosted: September 21st, 2016, 2:14
http://forum.acelaboratory.com/download ... &mode=view
PostPosted: September 21st, 2016, 7:52
HI
PostPosted: September 22nd, 2016, 14:30
N8000XX PCB
same idea of converting
http://www.hpwlab.com
PostPosted: September 25th, 2016, 0:10
Hi all,
anybody having PC-3000 UDMA Green card Driver kindly help me.
Safwan
PostPosted: October 2nd, 2016, 2:54
Hi Kamen,
Thanks for your link below.pls let me know that is not neccessery to disconnect sata in put from USB controller?
Safwan
PostPosted: October 2nd, 2016, 2:57
Hi
need to dissconnect any pins from Sata controller?
PostPosted: October 28th, 2016, 2:56
Hello , have you solved this case?
I kindly need the resources for this drive, have you saved them? Can you kindly share them?
Thank you
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 72 guests
