 Post subject: Seagate ST310211A swap pcb
PostPosted: November 1st, 2016, 15:39
I have a broken pcb on HDD Seagate ST310211A U5 10GB.
Configuration level 2AAABA
Configuration code YMH05
F/W 3.39
And I have one piece of donor HDD, the same type, but
Configuration level is 2EAABA
Configuration code is YDJ02
and F/W is 3.05
PCB ID are both 100112537 REV A
Questions are : Is it possible to swap the pcb and what sould I do ? Should I resolder some ic ? And which one ? Or should I buy the same F/W pcb ?
 Post subject: Re: Seagate ST310211A swap pcb
PostPosted: November 1st, 2016, 15:58
You could move the ROM chip, but it's not an easy one to move. This is before they were using the nice little 8 pin ones, and it'll be a lot harder to transfer. The easiest option would certainly be to buy a PCB with the correct firmware version.
PostPosted: November 1st, 2016, 16:21
Thanks, ok, I have an interest to buy one piece pcb ST310211A U5 10GB firmware 3.39 (Configuration level 2AAABA
Configuration code YMH05) Could anyone help me please ?
mail : ok1cdg@c-box.cz
PostPosted: November 1st, 2016, 20:07
Firmware 3.39
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 85 guests
