 Post subject: Interpreting 7 digits model number suffix of WD drives
PostPosted: August 30th, 2014, 14:30
Who can point me to the right document or a way to interpret the 7 last digits of this drive :
WD20NPVT-00Z2TT0
It's a 2 TB WD Green 2,5'' 15mm SATA hard drive coming from a MyPassport Studio USB/Firewire external enclosure.
The first part "WD20NPVT" can be explained with this document :
Model Numbers - WD Internal Drives
Model Number format fro WD Branded Products
This document tells that the model suffix number (after the hyphen) is only for in-house use.
However, I read in this forum that it was important to match the two digits at the middle of the suffix. True ?
Can someone explain the meaning of "Z2" (and possibly also of "TT") ?
Thanks.
 Post subject: Re: Interpreting 7 digits model number suffix of WD drives
PostPosted: August 30th, 2014, 14:33
Z2T is what is known as family code.
PostPosted: August 30th, 2014, 16:00
That information encodes internal model name and model version and can uniquely identify particular hardware build
PostPosted: August 30th, 2014, 17:32
I haven't seen WD's internal document, but here is an explanation in Russian:
http://www.acelab.ru/dep.pc/doc.pc3000d ... in-N-2.pdf
Here is Google's English translation:
http://translate.google.com/translate?h ... in-N-2.pdf
PostPosted: December 12th, 2016, 12:49
Thank you.
I wonder if the two last digits of the suffix, known as the "Customer configuration code" according to the document posted by fzabkar can not also be considered as the firmware version, or if you prefer, some kind of "Customer firmware code", as I own a
WD800JD 75MSA3
Firmware A3
Users browsing this forum: No registered users and 46 guests
