 Post subject: ST9750420AS
PostPosted: August 2nd, 2016, 16:11
Terminal output:
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067 FAddr:00380338
I need to know which points for read channel.
Thanks in advance friends.
Attached pictures and ROM :
ROM.rar [434.58 KiB]
Downloaded 438 times
 Post subject: Re: ST9750420AS
PostPosted: August 2nd, 2016, 16:26
Measure the voltages at the indicated test points.That should help us to differentiate between the read and write channels.
PostPosted: August 2nd, 2016, 18:11
Thanks for the reply Mr. Frank.
I will get to the office tomorrow and post the results.
Thank you.
PostPosted: August 3rd, 2016, 6:02
Banned User
wow good
Banned for spamming
PostPosted: August 3rd, 2016, 9:21
Thank you Mr. Frank :
PostPosted: January 25th, 2017, 7:28
I have similar case
So, The read channel the two point in the left side or in the right
and can you give me a procedure for how to apply this to get terminal access?
Expect, the Unexpected
Users browsing this forum: Google [Bot] and 70 guests
