 Post subject: Help with converting USB drive to Sata
PostPosted: February 16th, 2017, 23:17
I am trying to convert a samsung USB drive I have to Sata so that I can use it in my deepspar. The USB drive I have can be seen here http://www.ebay.com/itm/USB-3-0-HDD-PCB ... 2424851429?
The board I was thinking of using was http://www.ebay.com/itm/TOSHIBA-HDD-PCB ... 2424851429
I understand I have to match the MCU and motorchip and transfer ic602 from source board. I believe I matched things up correctly but just looking for confirmation.
Also I wanted to say that this is my first post here, I have read many threads in the past but recently have really dived into professional data recovery. Thanks for your help and I look forward to the community you all provide here.
Cheers!
 Post subject: Re: Help with converting USB drive to Sata
PostPosted: February 17th, 2017, 12:50
Should work.
PostPosted: February 17th, 2017, 14:50
Okay, I ordered it. Thanks for your help.
PostPosted: February 18th, 2017, 23:55
Will work if Main MCU and Motor controller are same
PostPosted: February 19th, 2017, 15:36
Just make sure you move the right IC :)
Do you not have DDI USB?
Data Recovery Cape Town
Users browsing this forum: No registered users and 52 guests
