 Post subject: I have some question
PostPosted: February 18th, 2017, 18:08
My computer has 3 drives ( 3 seperate OSes ) but only one OS is bad so I only want WIPE MY DISK for that bad OS . I do not want to wipe all 3 . How can I do it without open up my computer ?
THANK YOU VERY MUCH
LAM
 Post subject: Re: I have some question
PostPosted: February 19th, 2017, 10:51
Boot to one of the other OSs and format the affected partition
PostPosted: February 19th, 2017, 22:04
Rogfanther , I understand what you mean but I want to use low-level format of WIPE MY DISK software but WIPE MY DISK will wipe all 3 and I do not want that
PostPosted: February 20th, 2017, 20:27
What are the other OSs ?
You can make a full format of the partition. Just do not select for the quick format, and the effect will be the same as that software.
Also, depending of the other OSs you have installed, there may be other means.
So, what are them ?
PostPosted: February 20th, 2017, 20:34
I don't see why you you can't re-initialize the selected drive then zero it using Active @ Kill Disk, or even CCleaner.
PostPosted: February 21st, 2017, 9:02
I got it now . My problem is solved . Thank you all
Users browsing this forum: No registered users and 58 guests
