 Post subject: WD3200BMVV-11A1PS0 head compatibility
PostPosted: October 26th, 2016, 23:35
Hi Guys
I am looking for donor drive which is compatible with WD3200BMVV-11A1PS0 (4 heads) ,
anyone know which drive is compatible? thank you
 Post subject: Re: WD3200BMVV-11A1PS0 head compatibility
PostPosted: October 27th, 2016, 8:54
You can try checking the 5 last digits (A1PS0) - 11 is manufactured for some integrator. Try 160 gb HDD. Same architecture.
Check DCM also.
Sample : HHNNNTJMA (Motor, Headstack and Actuator/Preamp) . First digit (Motor = H) .
TJ code is essential. T = Headstack and J = Actuator.
HD RECOVERY
Sao Jose do Rio Preto - SP
BRAZIL
+55 17 32276226
+55 17 99639-0175
PostPosted: October 27th, 2016, 8:55
Denali is a donor for the SATA PCB and for the heads (WD3200BEVT-22ZCT0)
Mikippp
PostPosted: October 27th, 2016, 18:27
Thank you guys, hi Mikippp i found thats the perfect match. Thanks again.
PostPosted: March 10th, 2017, 8:30
I'm also currently working on a failed:
WD3200BMVV-11A1PS0 (Venus)
HHNTJHBB
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 0 : 932/2354
1 : 1 : 969/2409
2 : 2 : 8E0/2272
3 : 3 : 94A/2378
I attempted to use a Denali as a donor:
WD3200BEVS-26VAT0
DHCTJANB
Micro Jogs
0 : 0 : 93E/2366
1 : 1 : 8F5/2293
2 : 2 : 92C/2348
3 : 3 : 91E/2334
However, this failed to initialise the patient. Heads worked fine afterwards in the donor. Any one with any experience on the compatibility with these?
Thanks,
John
0161 408 4857
PostPosted: March 10th, 2017, 8:47
OK, just got this one initialised from a second Denali:
WD3200BEVT-75ZCT2
HACTJAB
Micro Jogs
0 : 0 : 9C6/2502
1 : 1 : 9AA/2474
2 : 2 : 9BA/2490
3 : 3 : 9D6/2518
Hopefully they will last the job.
0161 408 4857
PostPosted: March 10th, 2017, 10:59
For reference the first set of donor parts were also suitable; the patient HDD is very badly degraded. With both sets it has been possible to get to SA and read. Reading any user data is slow going.
Users browsing this forum: No registered users and 56 guests
