 Post subject: St100LM025 Ovly NOT loaded
PostPosted: March 25th, 2017, 12:14
Hello
power normal .no clicking . always busy
terminal output is :-
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
*PA_TI5565*PA VID=0012 PN=0055 Rev=0000- PA_TI5565 Found
*PA_TI5565*PA VID=0012 PN=0055 Rev=0000- PA_TI5565 FoundU
S_0SO_1
SPU@31'C,5068mV
IS=5
CLA ..36/61
HO..OK
HO RPM=2123 OK
AC 1357
ST..OK
mS1 00000003
GT:415
SC(L):4118/-3
BE.N:28
LD..OK
SK C: 7820 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1B
ResoTable Loaded. Rev:0x01
Bump Limit Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Fw Active 00
Ovly NOT loaded
eng>
_________________________________________
any clue please ?
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
 Post subject: Re: St100LM025 Ovly NOT loaded
PostPosted: March 25th, 2017, 14:08
I'm guessing that MOVLY001 is incompatible with the ROM code. MOVLY001 consists of two modules whose RAM load addresses need to match the ROM's FLASHTBL. If you can retrieve the ROM and MOVLY001, I can check them for you.
PostPosted: March 28th, 2017, 7:56
Thanks Fzabhar . i can retrieve the ROM only for sorry
Tawfeek Mokhtar
PostPosted: March 28th, 2017, 9:27
have you tried starting drive with head 1 & 2 ?
Data Recovery Pakistan
PostPosted: March 28th, 2017, 14:28
This is what I would be looking for:
http://www.hddoracle.com/viewtopic.php?f=59&t=698
You might like to verify whether your PCB is native by comparing the YYWW date codes on the ICs against the manufacturing date on the label.
PostPosted: March 28th, 2017, 14:42
i will tried to make head initialization in ram with no luck
Tawfeek Mokhtar
PostPosted: March 28th, 2017, 14:43
that's good point . i will try it . many thanks
Tawfeek Mokhtar
Users browsing this forum: Google [Bot] and 53 guests
