 Post subject: Is this hdd encrypted ?
PostPosted: June 6th, 2017, 4:02
Hi
I have external WD3200BMVV-11A1PS0 USB 3.0 head was stuck.
after fixing head stuck, convert USB to sata. I imaged the whole drive with few bad sectors.
now when scanning the drive with R-Studio, I get not result, except some PDF which comes with the drive.
PC3000 show no password,
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
and also the customer confirm he never had a password.
hex showing there is data in almost 80% of the drive.
Why I am not seeing any result?
attached sector 0,63,2048
Data.rar [1.2 KiB]
Downloaded 404 times
 Post subject: Re: Is this hdd encrypted ?
PostPosted: June 6th, 2017, 4:09
yes it is encrypted.
Data Recovery Pakistan
PostPosted: June 6th, 2017, 4:16
what type of encryption? is there a way to decrypt it?
PostPosted: June 6th, 2017, 4:29
If you have a Pc3000...it's all in the WD manual, check your update box.
http://www.rescue-it.se
PostPosted: June 6th, 2017, 5:00
this helped me.
http://blog.acelaboratory.com/pc-3000-f ... image.html
Thank you all
Users browsing this forum: Google [Bot] and 48 guests
