 Post subject: Samsung ST640LM000
PostPosted: June 21st, 2017, 20:11
Burnt PCB board
Will swapping a working board in cause any kind of data corruption?
https://drive.google.com/open?id=0BzJeewWhP0YqY0RsdTZrS1FRVjQ
 Post subject: Re: Samsung ST640LM000
PostPosted: June 22nd, 2017, 3:28
If preamp is burnt you can damage the data, so it must be sorted out before pcb swap.
PostPosted: June 22nd, 2017, 15:09
Motor driver IC. In this case you can get burnt preampifier or heads on the platters.
HSA shield with contacts - check voltage pins, at least, before using donor PCB. If it has no short circuit with common point or have no a very small resistance bidirectionally - it is good sign.
Sorry, photo isn't the best.
PostPosted: June 22nd, 2017, 18:37
Are you sure about your voltage test points? They seem like signal pins to me.
I would have guessed that the LC filters (?) would be in the supply paths.
http://ep.yimg.com/ay/yhst-14437584971410/hm641ji-hm641ji-s3m-rev-02-r00-c6493-g84a-aa6ag-rev-a-2-5-sata-samsung-pcb-fw-16.gif
PostPosted: June 23rd, 2017, 9:41
You are right, it's my fault, I'd put a picture for M8 family, but this is a M7E family.
Here is correct:
Users browsing this forum: Google [Bot] and 52 guests
