 Post subject: Toshiba - MQ03UBB200 Whats The Issue [ Rom/Heads/Platter ]
PostPosted: August 23rd, 2017, 8:19
Hi All,
Received This Case From a Routine Dealer .The patient tried to calibrate on sa ,Feels good but then starts knocking .I replaced the Heads To This From 2 Good Donors But Situation is Same .I could not see any contamination of the heads so i am ruling out surface degradation .I then took a good known pcb of same drive and tried that no knocking then is rom a issue in my case .The Rom is attached
PS : Frank i tried the rom cp extraction tools you made but both the tools could not find anything and said unknown rom .
rom.rar [443.33 KiB]
Downloaded 496 times
 Post subject: Re: Toshiba - MQ03UBB200 Whats The Issue [ Rom/Heads/Platte
PostPosted: August 23rd, 2017, 15:49
So many client say this drive get damaged without any reason ...
what about the original heads ? was it bent ?
or it's look fine ?
PostPosted: August 23rd, 2017, 16:58
It's not Head problem I think cause when you connect donor PCB with donor rom drive try to calibrate normal when you connect original Rom it start clicking ....
PostPosted: August 24th, 2017, 12:44
or it's look fine ?
Well,
To my trained eye they were perfect ,Not bent
PostPosted: August 24th, 2017, 12:47
Well,
This would mean donor head adaptives are different from patient head adaptives .Do we have any method to shift adaptives like wdc and seagate ? .On The Other Hand i do not have a data board for this which i should have to experiment a little .I am not a fanboy on usb to data converstion
PostPosted: August 25th, 2017, 2:42
or it's look fine ?
Well,
So it's High to be no media Damaged and i don't think it's a rom problem -
just update us about your case ..
regards
Users browsing this forum: Google [Bot] and 51 guests
