 Post subject: Seagate ST500DM002 After sorting hard disk detected but.....
PostPosted: August 24th, 2017, 13:21
Hello Friends...
I have a hard disk Seagate ST500DM002 KC 44 Firmware. It is not detected by bios at all. It has no suspicious noise at all. I apply BSY BUG FiX to this Hard Disk. But I didn't Success... After that i sort read panel and come in F3T> command and first i regenerate hdd and than clear smart. After that i connect hard disk to computer it now detected with its full capacity with unallocated space. When i run any Partition Recovery Software software gives me every sector is bad error...How i retrieve my data?
 Post subject: Re: Seagate ST500DM002 After sorting hard disk detected but.
PostPosted: August 24th, 2017, 18:10
this is consequences of trying to issuing commands read on the internet without understanding what as been done
PostPosted: August 24th, 2017, 18:30
I'm afraid you've made the situation much worse. Busy bug "fix" you likely applied does not apply to this model. Now you've probably tweaked the firmware really good.
The time to ask for advice is BEFORE you try things you don't understand, not AFTER you DIY it to death.
PostPosted: August 25th, 2017, 5:59
Please advice me to get back data or any suggestion please...
PostPosted: August 25th, 2017, 6:04
I reecieve this in terminal program...can any one solve problem?
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 060DA288 060D8574
Seg Write Preamble VBM start: 00000D3C end: 00000D63
Footer - start: 00000D65 end: 00000D8C
Seg Read Preamble VBM - start: 00000D8E end: 00000DB5
Footer - start: 00000DB7 end: 00000DDE
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00000026
[RSRS] 0008
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000001
MCMainPOR: Feature Enabled...
[SR] 0000
[SR] 0000
[SR] 0000
[SR] 0000
[SR] 0000
[SR] 0000
[SR] 0000
[SR] 0000
InitiateMarkPendingReallocateRequest for disc_lba: 00132F53!
InitiateMarkPendingReallocateRequest for disc_lba: 00132F54!
InitiateMarkPendingReallocateRequest for disc_lba: 00132F55!
InitiateMarkPendingReallocateRequest for disc_lba: 00132F56!
PostPosted: August 25th, 2017, 6:48
As informed by others above..
you have made your recovery more difficult than earlier..
if it is your drive and data is important, seek pro help in your area.
Users browsing this forum: Google [Bot] and 45 guests
