 Post subject: How to Fix Data Error (Cyclic Redundancy Check)!
PostPosted: September 7th, 2017, 7:42
Hi everyone!
I have a big problem with my Toshiba MQ01ABU032W 2.5" sata hard drive 320Go
more information plz visite : https://www.hdsentinel.com/storageinfo_ ... Q01ABU032W
or : https://toshiba.semicon-storage.com/ap- ... uxxxw.html
the problem is when i'm traing to format my HDD i have the message OF ata Error (Cyclic Redundancy Check)!
What is the problem that you think it might be? Please help!!
Thanks in advance ;)
File comment: This my HDD
 Post subject: Re: How to Fix Data Error (Cyclic Redundancy Check)!
PostPosted: September 9th, 2017, 6:08
thanx Spildit, for the answer but i need my HDD and i want fix it
PostPosted: September 9th, 2017, 9:26
Cyclic Redundancy Check error is caused by bad SATA cable or bad connection. Try repluging the SATA cable (on both sides) and changing it with a good one.
PostPosted: September 10th, 2017, 5:20
Thanks BGman, For the advice but i changed the SATA cable but i still have the same problem
PostPosted: September 10th, 2017, 6:30
Give us more details about the program you are using, the format you are trying to do, what is the exact message you are receiving.
PostPosted: September 10th, 2017, 9:13
okey, i use windows 32 bits to format but when i insialise the HDD whit MBR or GPT i recive the message of Data Error (Cyclic Redundancy Check) this is the picture
PostPosted: September 10th, 2017, 15:08
The drive is not being detected properly.
    238.47 gibibytes = 256.055 gigabytes
What does CrystalDiskInfo report?
PostPosted: September 13th, 2017, 9:28
Hi guys, and thanks for the help , MRs fzabkar, CrystalDiskInfo report givs me inconnu
PostPosted: September 13th, 2017, 18:34
Where was this drive being used before ? If it is from a DVR or something, that also would be one of the errors presented when formatting.
PostPosted: September 20th, 2017, 14:02
i don't know, may be it was in SERVER
PostPosted: September 20th, 2017, 18:17
Maybe ? It is a little hard then, because the drive could be somehow locked , personalized or had some other alteration in firmware done. Not necessarily bad.
One best solution would to take the drive with someone with pc3000 and the knowledge to a correct diagnostic before condemning the drive.
PostPosted: September 20th, 2017, 19:44
No one who's spent the money on a PC-3000 system is going to waste time trying to fix a broken drive when there's no data needing to be recovered. It's cheaper and easier to just buy another drive. Even if the OP manages to make the drive work for a bit, it's likely going to just fail again in short time.
PostPosted: September 20th, 2017, 20:25
Agreed. My comment for the pc3000 is mostly because the OP seems to not know from where the drive came, and so the reason/cause of the symptoms can“t be correctly assessed, due to lack of adequate tools. Someone with pc3000, or even Sediv, and the necessary knowlege, would be able to say if the drive is defective in some way, or is locked due to belonging to some other kind of machine/dvr/etc.
PostPosted: September 22nd, 2017, 6:01
thanks rogfanther, and data-medics, for the help but now what is the solution i don't have pc3000 and i don't know any one for help me can you do it for me PLZ !!!!
PostPosted: September 22nd, 2017, 8:01
xayd wrote:
but now what is the solution !!!!
The solution could come only after good diagnostics and you have done nothing about it. Start with the S.M.A.R.T. data from your drive, for example, than surface scan, etc.
PostPosted: September 22nd, 2017, 8:51
The cost of our time to us is worth more than the value of your drive...and at the end of the day, we all recognize that it is a waste of time, as the drive cannot be "fixed". It would be cheaper, faster and actually result in your getting a working drive back if we were to simply buy you a new hard drive.
here is a link to buying a replacement on E-Bay - https://www.ebay.com/p/Toshiba-320GB-In ... /194321179
PostPosted: September 22nd, 2017, 10:06
thanks BGman, for your help i will do some diagnostics and i will show you what i receved
and for you MRs lcoughey, you too thanks for the advice but i need my HDD and if you don't have any thing to give don't pute yourself in discussion ok bye
PostPosted: September 22nd, 2017, 18:28
That picture is too small. Can you provide a better one ?
PostPosted: September 24th, 2017, 6:54
Ok Mrs rogfanther, they are the new picture and thnks for the help
File comment: finaly this is the msg what i recerved
File comment: in this and when i want to inisialise my HDD they give me too methode MRT or GPT in each choise they give me CRC
File comment: This picture show me my HDD
PostPosted: September 25th, 2017, 10:33
I can see you are trying this with a lot of different computers.
Can you post a good picture of the disk label, please ? The one you used in the first post is too small.
Users browsing this forum: No registered users and 68 guests
