Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD20NMVW-11EDZS7
PostPosted: October 8th, 2017, 16:54
There's no encryption by Asmedia.
Mod. 25 has been checked.
The drive take approx. 45 secs to become ready
PostPosted: October 8th, 2017, 17:14
Probably, you didn't get what does the Self-Encrypted Drive. It doesn't matter what is the USB bridge.
PostPosted: October 8th, 2017, 17:33
Nobody is denying that the Asmedia bridge is a non-encrypting type. That was never my question. My question was, and still is, does the Asmedia bridge behave like a Jmicron, or something else?
The researchers state that there are, as of their writing, two non-encrypting bridges used by WD -- JMicron and Initio. The JMicron bridge is known to the OP -- he has already successfully circumvented the security on a 4TB SED using the information provided by the researchers (SA module 0x127). However, the same researchers appear to be saying that those SEDs behind Initio bridges have different SA components (which they decline to elaborate), and require a different approach when circumventing their security. Furthermore, they appear to be saying that there is some firmware related difference between a USB connected Initio-based SED and its equivalent SATA connected SED.
Perhaps the issue does not involve security, as toggling the SED flag in module 02 would suggest, in which case my observations may be a red herring.
PostPosted: October 8th, 2017, 17:47
I don't think that the problem with my drive related to security/encryption problem. I think it's related most to FW. Although, All SA modules appears OK.
PostPosted: October 8th, 2017, 17:52
why it matters of the drive was obviously converted to SATA?
PostPosted: October 8th, 2017, 17:54
if you do soft reset does the drive come ready immediately or does it take several seconds to become ready?
If it's the latter then some part of FW was not initialized properly
PostPosted: October 8th, 2017, 17:57
Soft reset takes 3-4 secs to become ready
PostPosted: October 8th, 2017, 18:25
Also when trying to get SMART attributes all ata registers turned red.
There's a faint sound i heared when start surface scan. And all registers turned red.
PostPosted: October 8th, 2017, 21:36
yes, some modules are not initialized
it could be indicator of unstable heads or other issues preventing quick reading of the modules
PostPosted: October 9th, 2017, 7:36
Both heads working perfectly (patient and donor) tested on the donor drive.
What specific mod/s could be responsible for that issue?
Thanks in advance.
PostPosted: October 9th, 2017, 10:11
unknown wrote:
Doomer wrote:
Thanks in advance.
Anything translator or adaptives related
PostPosted: October 9th, 2017, 10:20
Doomer wrote:
unknown wrote:
Doomer wrote:
Thanks in advance.
Smart hot swap may do the job?
PostPosted: October 9th, 2017, 10:22
Doomer wrote:
unknown wrote:
Doomer wrote:
Thanks in advance.
PostPosted: October 9th, 2017, 15:28
I don't think you would be able to do hotswap on this model but you can try
PostPosted: October 10th, 2017, 11:16
Agreed.
http://www.datasaversllc.com
PostPosted: October 10th, 2017, 12:44
jono-ats wrote:
Agreed.
+1 :D
Tested.
I have backed up mods. by ID and when I tried to read by track copy (1) gives errors and copy (0) backed up normally.
Is that gives any clue?
