 Post subject: MQ01ABF050 criteria for head replacment donor
PostPosted: October 30th, 2017, 10:38
Could you tell me what criteria should have donor for head replacement for this drive.
Patient detail:
MQ01ABF050
Drive rev: AAE AA01/AM001J
Date 12Jun2015
made in Philippinies
Are drive revision should be the same, or what part should be the same?
Marcin
 Post subject: Re: MQ01ABF050 criteria for head replacment donor
PostPosted: October 30th, 2017, 11:03
Toshiba drives are very forgiving of heads compatibility. Just match the model and the rev code up to the "/" and you should be fine.
PostPosted: October 30th, 2017, 11:32
Jared, if for example we have Toshiba MQ01ABD100 (which has 4 heads) and we need to change heads because head 0 is faulty, can we get heads from donor drive that has only 2 heads (example from MQ01ABD050) so that we can clone surface 0 ?
My firmware database:
PostPosted: October 31st, 2017, 3:32
For examply this drive should be OK?
Rev: AAD AB00/AM0P1D
Date 23 december 2015
About revision you have mean first part this code: AAD
In patient I have AAE.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 48 guests
