 Post subject: ST1500DM003 not detected
PostPosted: August 29th, 2015, 10:24
Hello, would appreciate some help with figuring out how to recover data from my hdd.
Some info:
SN: F240A3B7
FW: CC4B
POST freezes for ~1m while detecting drives, then proceeds to load w/o this drive detected, no abnormal noises.
Terminal log:
Boot 0x40M
Spin Up
TCC-001C[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001C
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 0A61
Nonvolatile MCMT sequence number 020E445C
[RSRS] 003D
ProcessRWError -Read-   at LBA 0000000000003175  Sense Code=40000087
ProcessRWError -Read-   at LBA 0000000000003189  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000000318D  Sense Code=40000087
ProcessRWError -Read-   at LBA 00000000000032BF  Sense Code=40000087
ProcessRWError -Read-   at LBA 00000000000033CE  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000033CE!
ReadFooters (Forward): Segment 003D StartLBA 0000000000018A98 Starting Footer LBA 0000000000018B70
  SeqNum 020E445D  TotalUserBlocks 0058
  Valid Footer Obtained:  ID/Seq D0D0CAFE 020E445D 00000000 00000000
[SW] 0005
Reconstruction: Completed 1:  Reconstruction occurred
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001D
LED:00000047 FAddr:FFFFFFFE
Thanks in advance.
 Post subject: Re: ST1500DM003 not detected
PostPosted: November 2nd, 2017, 19:40
I have the same problem with this drive.
PC Bios will not detect Hd. Tried all the simple steps to revive it:
1. cleaned PCB contacts
2. StarTech IDE USB connector
I would really appreciate help. I have been researching on the web and the most likely problem is the firmware?
If so I would like to know how to fix it.
Pls let me know what path to take.
Thanks.
PostPosted: November 2nd, 2017, 23:44
If you really need data - the only correct way is to take it to some DR lab
PostPosted: November 3rd, 2017, 13:59
More info on my dead Samsung drive.
It spins but undetected in BIOS.
The condensers are fine on the PCB.
I understand these drives suffer from firmware problems and there are DIY solutions.
I am hoping someone will have the patience to provide some guidance.
Thanks.
PostPosted: November 3rd, 2017, 16:44
Start by determining whether your drive is a Seagate or a Samsung.
PostPosted: November 3rd, 2017, 17:57
My apologies.
I have a Seagate dr. ST1500DM003.
Users browsing this forum: No registered users and 52 guests
