 Post subject: Wd My Passport Essential (USB 3.0) fail.
PostPosted: January 23rd, 2015, 4:18
Wd 500gb usb 3.0
Try to recover my photos.
Test it with other usb 3 cable not.
Hdd led on.
Hdd work no spin, no noise. normal motor rotate
No sign USB NOT RECOGNISED
Pcb version 2060-771737-000 rev A
I must found the same pcb to test
Pin out to make it sata?
 Post subject: Re: Wd My Passport Essential (USB 3.0) fail.
PostPosted: January 23rd, 2015, 5:15
you should change usb interface to sata
or simply you can install 2060-701692-000 rev p1 this is sata compatible with your pcb
http://www.hpwlab.com
PostPosted: January 23rd, 2015, 6:06
how i can change usb interface to sata? pinouts to solder a sata cable?? what capacitors remove?
if i change board i must change bios too?
PostPosted: January 23rd, 2015, 6:30
i write this long time ago
you can check this link
http://www.hpwlab.com/hdd/thread-989-1-1.html
this explain how can you change USB to SATA Interface
i try to upload photo here
but size is big
PostPosted: January 23rd, 2015, 7:03
http://www.hpwlab.com/hdd/data/attachme ... c8dm9c.jpg
http://www.hpwlab.com/hdd/data/attachme ... i2nwzd.jpg
PostPosted: January 26th, 2015, 5:13
A+ = E?
A- = E?
B+ = E?
B- = E?
i plug in directly to sata port in computer??
PostPosted: January 26th, 2015, 7:51
johann69 wrote:
A+ = E?
A- = E?
B+ = E?
B- = E?
yes, directly to SATA cable
PostPosted: January 26th, 2015, 8:53
what pinout to sata pin?
PostPosted: January 28th, 2015, 4:11
A+ is E71 or E72 or E73 or E75?
A- is E71 or E72 or E73 or E75?
B+ is E71 or E72 or E73 or E75?
B- is E71 or E72 or E73 or E75?
what is correct?
PostPosted: January 29th, 2015, 19:22
These two PCBs use the same Marvell MCU (88i9146-TFJ2):
http://ep.yimg.com/ay/yhst-144375849714 ... v-p1-9.gif
http://ep.yimg.com/ay/yhst-144375849714 ... t-fw-5.gif
Follow the SATA Tx/Rx pins to the SATA data connector.
PostPosted: February 3rd, 2015, 9:06
i undrestand what have to do.
i try to find the Marvell MCU (88i9146-TFJ2) pinout diagram to solder the sata connector to the E71 , E72 , E73 , E75 pinout.
it is not mater who i solder it? not thing so.
i must solder / connect it right.
i am asking if you know what is each pinout on the board.
is E71 A+ / TXP or is A- / TXN or is B+ / RXP or B- / RXN ????
Thanks for your help
PostPosted: February 3rd, 2015, 15:03
Is no one going to tell this guy the obvious limitation... that the data will be encrypted if you read it through SATA?
PostPosted: February 5th, 2015, 4:20
Ok , thanks, the only way is to change the board with the same and if it works ok.
or find sata board and change the bios and ok to read it then?
PostPosted: January 5th, 2018, 11:44
hello!
I compared two hard drives.
WD5000BMVW and WD3200BPVT.
The result of the comparison you can see in the pictures.
Image Image
Image Image
Image Image
Users browsing this forum: pepe and 64 guests
