 Post subject: Seagate ST4000DM000 File Recovery Problems
PostPosted: December 25th, 2017, 23:32
I accidentally did a quick format on my HDD and have been trying various recovery software to retrieve the data. The software usually find files but the problem I'm having is when I recover the files they are usually corrupt/unreadable - PDF and RAR compressed files.
I've tried Getdataback Simple, Easeus, Pareto Logic Data Recovery and Seagate Recovery Suite (did not complete) - scans take about 8 hours to complete
Anyone know why the files are not recovering correctly?
Is there a way to recovery these files?
 Post subject: Re: Seagate ST4000DM000 File Recovery Problems
PostPosted: December 26th, 2017, 2:24
hi,
did you save Data in same Drive after Data Recovery ? if yes then that the Reason Data is overwritten.
PostPosted: December 27th, 2017, 7:47
No
Nothing has been written to the drive since the accidental format.
The only software I've tried that is able to recover rar files and open then without and errors is EaseUS Data Recovery.
The only problem is that the recovered files don't retain their original names making identification a bit difficult.
PostPosted: December 28th, 2017, 10:14
was this drive came from external box ?
can assist remotely if interested
Data Recovery Pakistan
PostPosted: January 5th, 2018, 6:30
amjnm wrote:
No
That is RAW recovery, all files which been fragmented is not gonna work after such recovery
Angel Data Recovery
PostPosted: January 7th, 2018, 0:14
At least on a Windows system, significant amounts of data can get overwritten even on a completely idle NTFS re-formatted HDD. Space where former files used to be located being marked as free, system files can go wherever the system wants, most notably journaling files.
If you can recover files in raw modes, at least those files must be intact, their contents must be intact, but their records in the MFT may have been altered. When the MFT has been completely overwritten (unlikely here after a quick format, and the recovery softwares wouldn't be able to recognize any folder structure whatsoever), the metadata is lost, meaning that the names, timestamps and other properties can not be recovered, even if the contents of all files are still 100% valid, in which case only raw recovery is possible.
R-Studio would be worth trying, it usually is very efficient at reconstructing a folder structure when the filesystem has been significantly altered (and can also do raw file recovery, targetting pretty much all common file formats).
TestDisk may be able to recover the former partition in-place, although it's quite risky. It can extract a full image beforehand, but for a 4TB HDD it's quite a chore. Its companion program Photorec is designed for raw file carving, it's been recognized as one of the most efficient solutions available for that task, challenging very expensive professional forensics suites despite being free (it's not perfect though, I've noted some shortcomings in particular situations, and in case files are fragmented there's little chance that it's going to recover them completely). If you really can't recover the folder structure, it's certainly not ideal, but it's certainly better than nothing!
PostPosted: January 7th, 2018, 4:08
are you talking about SSD drive?
PostPosted: January 7th, 2018, 5:59
sorry did not notice the seagate 4tb Title
:oops:
Users browsing this forum: pepe and 62 guests
