 Post subject: Invalid geometry after pcb swap
PostPosted: January 6th, 2018, 9:12
WD hdd has 771959 sata board and works perfectly. Trying to test a 771962 usb board coming from a faulty drive (all heads gone). The sata hdd with the usb pcb is detected in device manager but fails to show up in disk management. Victoria says invalid geometry and 0 size. Can somebody explain why this happens and how to fix geometry?
Those who know don’t talk. Those who talk don’t know.
 Post subject: Re: Invalid geometry after pcb swap
PostPosted: January 17th, 2018, 5:00
771962 pcb has a different controller chip than 771959! This way these two pcb's are not compatible.
PostPosted: January 17th, 2018, 12:19
The matching board for 771959 is 771494. However as Spildit says you need to swap the ROM and it may not work due to encryption. I have never tried this the wrong way round (swapping SATA with USB) so let us know how you get on.
Users browsing this forum: pepe and 51 guests
