 Post subject: Seagate ST2000LM007
PostPosted: January 10th, 2017, 14:46
Seagate ST2000LM007. Spins up, stays spinning but diagnostic port is locked on this model and PC3000 as yet doesn't support it by the looks of it. Goes ready but if I try to do anything with it, it just hangs up. No ID. Anyone had any luck with these, first one Ive seen and by what Ive read its not nice to work on.
F3 T>Z
Diagnostic Port Locked
F3 T>
Boot 0x80M
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00003A90 At SU: 000F1A17 NT: 00000002 OT: 00000001
(POR) Recover Secondary MCMT Opened Recovered
Starting LBA of RW Request=000E6D2EF0 Length=000011F0
ProcessRWError -Read- at LBA 000E6D3038 Sense Code=43110081
AttemptErrorRecovery-0
ERC TO exceeded, orig value in us:FFFFFFFF
MS Read Fails: 73697780,00008F80
Xor this IOEDC Syndrome with Host LBA to find actual sector written = 00009A00
Search IOEDC Index = 0001240B Index Offset = 00000000
Search IOEDC Index = 0001240C Index Offset = 00000001
Search IOEDC Index = 0001240D Index Offset = 00000002
Search IOEDC Index = 0001240E Index Offset = 00000003
Search IOEDC Index = 0001240F Index Offset = 00000004
Search IOEDC Index = 00012410 Index Offset = 00000005
Search IOEDC Index = 00012411 Index Offset = 00000006
Search IOEDC Index = 00012412 Index Offset = 00000007
Search IOEDC Index = 00012413 Index Offset = 00000008
Search IOEDC Index = 00012414 Index Offset = 00000009
Search IOEDC Index = 00012415 Index Offset = 0000000A
Search IOEDC Index = 00012416 Index Offset = 0000000B
Search IOEDC Index = 00012417 Index Offset = 0000000C
Search IOEDC Index = 00012418 Index Offset = 0000000D
Search IOEDC Index = 00012419 Index Offset = 0000000E
Search IOEDC Index = 0001241A Index Offset = 0000000F
Search IOEDC Index = 0001241B Index Offset = 00000010
Search IOEDC Index = 0001241C Index Offset = 00000011
Search IOEDC Index = 0001241D Index Offset = 00000012
Search IOEDC Index = 0001241E Index Offset = 00000013
Search IOEDC Index = 0001241F Index Offset = 00000014
Search IOEDC Index = 00012420 Index Offset = 00000015
Search IOEDC Index = 00012421 Index Offset = 00000016
Search IOEDC Index = 00012422 Index Offset = 00000017
Search IOEDC Index = 00012423 Index Offset = 00000018
Search IOEDC Index = 00012424 Index Offset = 00000019
Search IOEDC Index = 00012425 Index Offset = 0000001A
Search IOEDC Index = 00012426 Index Offset = 0000001B
Search IOEDC Index = 00012427 Index Offset = 0000001C
Search IOEDC Index = 00012428 Index Offset = 0000001D
Search IOEDC Index = 00012429 Index Offset = 0000001E
Search IOEDC Index = 0001242A Index Offset = 0000001F
Search IOEDC Index = 0001242B Index Offset = 00000020
VBMIndex With IOEDC Error =0001242B
Uint32 Offset= FFFFFFFF Bit Mask= EEEEEEEE
HostLBA = 0000000073697EE8
Previous VBM Index = 0001242A
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
00007EE7 00000000 7EA562EE 00000000
VBM Index IOECC Error =0001242B
0000E4E8 00000000 A8908B74 00000000
Next VBM Index = 0001242C
0000E4E9 00000000 33C4927A 00000000
DiscLBA on or before IOEDC Error = 0E6D2FD9
DSC PASS
ProcessRWError -Write- at LBA 000E6D2FD9 Sense Code=44808780Out:
Search IOEDC Index = 00012413 Index Offset = 00000000
Search IOEDC Index = 00012414 Index Offset = 00000001
Search IOEDC Index = 00012415 Index Offset = 00000002
Search IOEDC Index = 00012416 Index Offset = 00000003
Search IOEDC Index = 00012417 Index Offset = 00000004
Search IOEDC Index = 00012418 Index Offset = 00000005
Search IOEDC Index = 00012419 Index Offset = 00000006
Search IOEDC Index = 0001241A Index Offset = 00000007
Search IOEDC Index = 0001241B Index Offset = 00000008
Search IOEDC Index = 0001241C Index Offset = 00000009
Search IOEDC Index = 0001241D Index Offset = 0000000A
Search IOEDC Index = 0001241E Index Offset = 0000000B
Search IOEDC Index = 0001241F Index Offset = 0000000C
Search IOEDC Index = 00012420 Index Offset = 0000000D
Search IOEDC Index = 00012421 Index Offset = 0000000E
Search IOEDC Index = 00012422 Index Offset = 0000000F
Search IOEDC Index = 00012423 Index Offset = 00000010
Search IOEDC Index = 00012424 Index Offset = 00000011
Search IOEDC Index = 00012425 Index Offset = 00000012
Search IOEDC Index = 00012426 Index Offset = 00000013
Search IOEDC Index = 00012427 Index Offset = 00000014
Search IOEDC Index = 00012428 Index Offset = 00000015
Search IOEDC Index = 00012429 Index Offset = 00000016
Search IOEDC Index = 0001242A Index Offset = 00000017
Search IOEDC Index = 0001242B Index Offset = 00000018
DiscLBA on or before IOEDC Error = 0E6D2FDA
ProcessRWError -Write- at LBA 000E6D2FDA Sense Code=44808780Out:
Search IOEDC Index = 0001241B Index Offset = 00000000
Search IOEDC Index = 0001241C Index Offset = 00000001
Search IOEDC Index = 0001241D Index Offset = 00000002
Search IOEDC Index = 0001241E Index Offset = 00000003
Search IOEDC Index = 0001241F Index Offset = 00000004
Search IOEDC Index = 00012420 Index Offset = 00000005
Search IOEDC Index = 00012421 Index Offset = 00000006
Search IOEDC Index = 00012422 Index Offset = 00000007
Search IOEDC Index = 00012423 Index Offset = 00000008
Search IOEDC Index = 00012424 Index Offset = 00000009
Search IOEDC Index = 00012425 Index Offset = 0000000A
Search IOEDC Index = 00012426 Index Offset = 0000000B
Search IOEDC Index = 00012427 Index Offset = 0000000C
Search IOEDC Index = 00012428 Index Offset = 0000000D
Search IOEDC Index = 00012429 Index Offset = 0000000E
Search IOEDC Index = 0001242A Index Offset = 0000000F
Search IOEDC Index = 0001242B Index Offset = 00000010
DiscLBA on or before IOEDC Error = 0E6D2FDB
ProcessRWError -Write- at LBA 000E6D2FDB Sense Code=44808780Out:
Search IOEDC Index = 00012423 Index Offset = 00000000
Search IOEDC Index = 00012424 Index Offset = 00000001
Search IOEDC Index = 00012425 Index Offset = 00000002
Search IOEDC Index = 00012426 Index Offset = 00000003
Search IOEDC Index = 00012427 Index Offset = 00000004
Search IOEDC Index = 00012428 Index Offset = 00000005
Search IOEDC Index = 00012429 Index Offset = 00000006
Search IOEDC Index = 0001242A Index Offset = 00000007
Search IOEDC Index = 0001242B Index Offset = 00000008
DiscLBA on or before IOEDC Error = 0E6D2FDC
ProcessRWError -Write- at LBA 000E6D2FDC Sense Code=44808780Out:
Search IOEDC Index = 0001242B Index Offset = 00000000
DiscLBA on or before IOEDC Error = 0E6D2FDD
ProcessRWError -Write- at LBA 000E6D2FDD Sense Code=44808780Out:
Unretryable write error
(MC POR Duration): 0000002227
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
FAFH_TRIGGER_POWER_UP
 Post subject: Re: Seagate ST2000LM007
PostPosted: January 11th, 2017, 23:36
address to Pepe or Doomer
PostPosted: January 12th, 2017, 5:47
I've done 3 of these so far, 2 needed headswaps and I can't remember the other one. I don't remember much else than headswaps are a bit of a pain with the ramp. I'm still running an older version of PC3K as me and the newer versions just don't get on so I don't think I had much access to the SA either, but I recovered all 3 of them somehow. Luck.
Data Recovery Cape Town
PostPosted: February 11th, 2018, 22:17
Any luck with this? I have a drive with similar issues.
PostPosted: February 11th, 2018, 23:01
No known DIY solutions for this. Only a professional can help.
Where in the US is the drive located? We can suggest somebody.
PostPosted: February 12th, 2018, 3:10
me too.
PostPosted: February 13th, 2018, 3:59
Terminal log shows only part of the problem, but we also can help with these drives, so you can count me in on the list too.
Users browsing this forum: No registered users and 108 guests
