 Post subject: Repair PCB, need ROM short point PCB 1292
PostPosted: February 12th, 2018, 17:05
need short point PCB 1292 to terminal write ROM
 Post subject: Re: Repair PCB, need ROM short point PCB 1292
PostPosted: February 12th, 2018, 18:10
https://i.imgur.com/yoiEUpE.jpg
https://i.imgur.com/pejdHrO.jpg
File comment: 1292
PostPosted: February 12th, 2018, 18:24
File comment: 2
File comment: 1
PostPosted: February 15th, 2018, 17:12
:roll: :roll: :roll: :roll: :roll: :roll: :?: :?: :?:
PostPosted: February 18th, 2018, 21:05
Can an Admin or Moderator answer?
PostPosted: February 19th, 2018, 14:27
Hi, what do you think you will accomplish on shorting on that pcb?
http://www.rescue-it.se
PostPosted: February 20th, 2018, 15:06
:?: :!: :?: :arrow: :arrow: :arrow:
PostPosted: February 20th, 2018, 18:07
There is no terminal on that pcb, for read/write ROM you need to put the pcb in safe mode by use jumpers...or through ATA with right programs if pcb is healthy....otherwise move ROM chip to a new board.
PostPosted: February 20th, 2018, 18:31
right programs write ROM :?: :?: :?:
PostPosted: February 20th, 2018, 19:02
Try to use the search function, it actually works!
I did put in: program read rom....got 174 hits.
PostPosted: February 20th, 2018, 19:07
Thanks Reply
Users browsing this forum: Google [Bot] and 52 guests
