 Post subject: Smart Fail Toshiba MK6465GSX
PostPosted: March 10th, 2018, 4:56
Hello My Friends
I have a toshiba hdd model MK6465GSX and problem is smart fail And Speed is very low !
i need fix this HDD and i connect TX RX Connector and open hyper terminal and config bit per second 9600 and trun on hard disk but nothing to happened and not show anything on hyper terminal console !
my usb to ttl convertor chipset is cp2102 .
Is there a problem with the converter?
i,m check 3 model toshiba hdd with this convertor but not working , and i chek with seagate hdd and working convertor !
how can i access toshiba hdd terminal ?
Regard , thanks
Sorry English is not my first language .
 Post subject: Re: Smart Fail Toshiba MK6465GSX
PostPosted: March 10th, 2018, 7:13
My poor advice: trash this drive and buy a new one.
Good luck
PostPosted: March 10th, 2018, 11:13
If you are sure of that speed of 9600, try pressing Enter after turning on the disk
Users browsing this forum: Google [Bot] and 50 guests
